Old 03-21-2025, 03:19 PM   #1
Detour
Help finding clutch linkage
I have been struggling to find a replacement clutch link that matches what is on my 67' K20. I ordered one off of LMC but it is just a round rod with a 90 bend at the end so that will be way off alignment. Any idea where to find it or if it is not the original piece, what vehicle is it from?
At this point I have two options.
1. Take the one off the truck and weld up the groove and file it back to size.
2. Bend the rod from LMC and hope to get an angle and end length that works.
Detour is offline   Reply With Quote
Old 03-21-2025, 03:41 PM   #2
awryexperiment
Re: Help finding clutch linkage
I'm not sure if two styles of rods were used on these trucks.
My 72 has a rod identical to yours, partially flat, including the worn/grooved ends. However, when I search on ebay I see multiple listings for used clutch pedal assemblies and rods that are round stock only.
Are you concerned with authenticity or functionality (or both)? If function is solely your objective, then just bend the new one to match the old one. I don't think it will matter if you are a few mm off.
awryexperiment is offline   Reply With Quote
Old 03-21-2025, 03:43 PM   #3
pjmoreland
pjmoreland's Avatar
Here's the only place I've seen that sells a reproduction of the "dog leg" style bent clutch pushrod. It's out of stock though, unfortunately.
https://classicparts.com/67-72-upper-clutch-rod
pjmoreland is online now   Reply With Quote
Old 03-21-2025, 03:49 PM   #4
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: Help finding clutch linkage
There were two styles of pedal to Z bar rods in this series of truck.
I too am looking for this style of clutch rod for my 1970 K20. They seem to be few and far between.
If that were mine, I would have zero qualms welding up that groove, then cleaning it up and running it. It would last another 58 years if lubed.
Old 03-21-2025, 06:07 PM   #5
Detour
I’m just concerned with functionality in which way is easiest. The remainder of the clutch linkage is pretty butchered and I’m trying to fix it and get rid of the extreme excess slop.
Thanks for the link. I might contact them and ask if there are expectations for restocking.
Otherwise I might be trying to weld to fill the groove.
Old 03-21-2025, 08:30 PM   #6
RustyPile
RustyPile's Avatar
Over the years, there have been variations of this rod,. Also variations in the "Z Bar". The curved rod requires a certain "Z bar. Same applies to the straight rod.... There are differences between the V-8 linkage and inline 6 linkage. Nothing aligns properly if the parts are intermixed.
Weld up that groove and reshape it with a file and grinding wheel.. A Dremel Tool works very well for this. If the holes are elongated, weld up the hole and redrill... Sometimes the "Z bar" will wear a circular groove in the frame bracket.. Remove the bracket and weld a bead in the groove and metal finish the weld.. Reattach the bracket using grade 8 bolts. Lubricate all pivot points with wheel bearing grease. Over the years, I've repaired numerous clutch linkage pieces using this method.
RustyPile is offline   Reply With Quote
Old 03-22-2025, 10:28 AM   #7
Sheepdip
Sheepdip's Avatar
This is where I bought my replacement parts and fit perfectly. FYI I bought the whole enchilada, so everything was new and tight.
https://4speedconversions-com.3dcart...k_linkage.html
Sheepdip is offline   Reply With Quote
Old 03-24-2025, 12:04 PM   #8
70STOVEBOLT
70STOVEBOLT's Avatar
I have a rod at home, let me take a look at it and see what type it is. I think it came off my truck when I switched to an automatic, so a '70 with a 250/3OTT I will report back.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 03-24-2025, 06:59 PM   #9
Detour
Thanks Sheep. Looks like they are sold out but another option I can keep an eye on.
Appreciate you looking for me.
Old 03-24-2025, 07:33 PM   #10
70STOVEBOLT
Mine is round stock
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
Old 03-26-2025, 02:41 PM   #11
1970cstblazer
Arrow Re: Help finding clutch linkage
https://67-72chevytrucks.com/vboard/...9&postcount=71
