Old 03-27-2025, 09:58 AM   #28
A1971Blazer
A1971Blazer's Avatar
Re: Computer mounting location
I mounted my PCM on the core support and built a load center for the relays and fuses. While I was at it, I put my headlights on relays. All power comes to a terminal block under the fuse box mount.
this picture was during the wiring process
I fabricated a mount for the fuse box and used a modified GM mount for the PCM
on the underside is the terminal block
also used a circuit breaker for the headlights
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
