Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 03-28-2025, 02:22 AM   #151
Richard
Re: Bucketlist Blazer -Restomod build 6.6liter L8T
Great to see the progress you have made. Waiting to see first drive! I can see wanting to bolt that stuff on. Should not be out without most of the clothes on
Richard
Old 03-28-2025, 08:56 PM   #152
NDM
P182E code. Look it up. It is the only thing keeping me from moving.
I have to drop the trans pan to check for the simple stuff but may need a Fv[k!nG tcm. I really hate trans fluid. I always spill everywhere and dribble it down my arms.
I am obviously super pissed because my Blazer is fully assembled minus the front driveshaft and I cannot drive it.
Hopefully it is a simple problem.
NDM is offline   Reply With Quote
Old 03-29-2025, 04:23 AM   #153
Richard
I am sure you looked it up. Not at all familiar with the terminator. I used an oem ecu. Before tearing into the trans I would look at a connection to the neutral safety switch. Maybe bad or connected incorrectly. If you have done some investigation you will know where I am pointing to.
Richard
Old 03-29-2025, 01:57 PM   #154
NDM
Absolutely hate trans fluid!
Hopefully the white IMS is the issue. A new one will be here tomorrow. If not, then the whole tcm will come out and hopefully get replaced Monday. I am about ready to drive all the way to Missouri to have this dude program a new tcm. This is such a pain in the royal @ss!
Did I mention how much I hate trans fluid?
Old 03-29-2025, 02:02 PM   #155
NDM
The holley has a yellow wire that is supposed to ground when you are in park or neutral. The problem is that the holley does not know when it is in those gears because the 6l90e is not telling it when it is in gear. I ordered the internal mode switch (IMS) for another $45 and it will be here tomorrow. If that does not work, TCM it is. If neither of those work I ..............I don't fricking know what to do.
Old 03-30-2025, 01:44 AM   #156
Richard
My simple mind thinks that the ground on that wire should inform the ECU that vehicle is in park or neutral? My PSI harness instructions for the LSA/6L90 say that the wire connection is optional. In fact the wire is not present on the harness purchased from them. Maybe a setting needs to turned off in the ECU?
Richard
Old 03-30-2025, 08:22 AM   #157
NDM
Correct. The wire is supposed to ground when in park or neutral. The trans is not sending that ground signal. When I shift. I will look into the settings this morning while I wait for the Ims delivery.
Old 03-30-2025, 06:51 PM   #158
NDM
Nope IMS did not work. I am lost as to why the trans is not showing which gear I am in. I am faced with buying another $500 part that I do not know will work. Wtf
I just want to drive my damn Blazer.
Old 03-31-2025, 01:02 AM   #159
Richard
Sorry, maybe I to dumb to get it? The trans does not send a signal. It sees the ground. Are you sure the connect point is providing ground in neutral and park? Did you try direct grounding the wire and see if it works?
Richard
Old 04-02-2025, 12:04 AM   #160
NDM
When the trans tcm tells the ecu that is in park or neutral, the ecu grounds the yellow wire. Since the tcm is not telling the ecu what gear it is in, the trans will not ground that wire.
Old 04-03-2025, 06:31 PM   #161
NDM
A car guy helped me realize what is likely my issue and it ain't good. He owns a trans shop and after I told him that it won't heat up to operating temp and given that I can now see p,r,n and drive, he knew what it probably is. He says, "You probably broke your pump during install". Oh crap! That makes 100% sense. It is not pumping fluid so therefore it is not able to get up to temp.
I am looking at a grand if I bring it to him and 1500 if he has to do it. Damn!
Old 04-03-2025, 11:26 PM   #162
NDM
As he was telling me what he thinks was wrong, I remember when I was putting in the trans and heard a funny loud sound. At that moment I realized that the noise was the simple but major mistake I made. I just wish I had positioned the trans better and avoided this costly mistake.
At this point, while I have done everything myself, I amjust going to drop off the Blazer by tow truck and let him work his magic. I am blowing through cash trying to fix it myself. At lease I can rest knowing thatI should be able to drive it home when he is done.
For those that are installing their own transmissions, make sure you seat the trans flat on the motor before tightening those bolts. Mine had gotten hung up and I apparently ramrodded it in there. Costly mistake that I knew better.
Funny thing is that the techm actually fixed the other issues! I can see all gears now but the broken pump will not allow fluid to move through the trans. Soooo close to driving it!
So I will get it towed on Monday and hopefully drive home on tuesday with empty pockets!
Old 04-04-2025, 06:36 PM   #163
NDM
First time that we have been apart in months. Not sure how that door got so misaligned though.
Old 04-10-2025, 06:00 PM   #164
NDM
Yesss!!!
It is home and the shakedown begins!
It drove pretty fine on the short trip. Now I have to drive it to tune it. I already know that the steering rack is leaking (preexisting) and that I need to run the exhaust out the sides.
It rumbles so nicely!
I really messed up that pump!
Old 04-12-2025, 05:08 PM   #165
NDM
Shake down-
1. Power steering rack is leaking like crazy. Need a new one or rebuild.
2. Brakes are terrible. I know that I need hydroboost but the brakes also need to be serviced.
3. passenger front leaf spring is broken...like not falling off broken but broken. Time to get on that 4 link build or buy a couple springs. Probably will bet the leaf springs for now. Hell I can build a 4 link for less than leaf springs though.
Old 04-13-2025, 11:58 AM   #166
NDM
It has already seen highway duty and holy crap! I have been nervously giving it a little more and a little more abuse. I am nervous about breaking something. We'll yesterday, I accidentally whooped on the gas and those 33in tires broke loose into a loud screech! I was pleasantly surprised so I started giving more throttle from light to light. Let me be very clear when I say, "this thing is definitely no longer slow"! I am not even on e85 yet and this mofo scoots. I need not brake torque it to break the 33's loose. The best part is that I can throttle it like a grandpa and it is totally composed. When I stomp the gas though, the animal emerges.
I think that this cam profile is going to be fantastic for what I am going for. The ability to lightly accelerate when I want and pure violence when I feel the need.
I am looking forward to giving it just a little bit more each day now. As of yesterday, it really came alive after I tuned the 6l90e trans.
Old 04-15-2025, 10:53 AM   #167
NDM
Uh Oh!....Got my e85 sensor working tonight. I may add some to my tank just to see if the changes that I am making to the tune are working.
What is cool it that I can see what ethanol % is in the fuel that I pump. Obviously, I would need to either drain the old fuel first or I can just fill the tank when really close to empty. For now, I want to add a little e85 to my fuel at a time to watch the ethanol content with my sensor readings. It is an AC delco/continental part that GM uses so I am confident in it's accuracy more or less.
Tonight's discovery. ... we'll ain't that some sh!t!
I took this photo on the highway quickly to document my rpm vs speed at around 79mph. I noticed that it was not matching the glonass gps. Huh....that is weird. So later I decide to try to get some E85 before bed and googled what the gears are on a 72 k5. It said 3.73 for a manual and 3.08 for auto. Well my holley is set for 3.73. So I head out with my computer and change the ratio to 3.08...way off! So I go the opposite way for grins and lo and behold, my gear ratio is 4.10! That must be why my old motor hollered so loud on the highway with the sbc350 and 3 speed trans. It took off fast quick ish though.
So now I have 4.10 gears and good trans gears....technically I could get some 4.56 gears to bring out more of the animal. 🤔
Most times you hate the previous owner. In this case, I wish I could thank them!
Old 04-15-2025, 11:02 PM   #168
NDM
As of tonight, I am up to 49% E85 in the tank. It has already started coming alive. It rips so hard! I am talking very violent when the light turns green. I can feel the frame doing weird stuff though. I will need a bunch of stiffening if the body and frame. I am super disappointed about one thing though. It appears that these tires do not leave streaks on the road. I did a couple nasty rips off the line and went back to snap a few pic to share with you guys. To my surprise there was nothing there. I 100% know that the tires were spinning and there was nothing. That is not cool.
I know that you guys probably think that I am being dramatic about this thing. I am talking about the Blazer from the perspective of the cars that I have owned (below). So far the Blazer feels more violent than all of them. I have not gone full throttle yet because I am scared to break the original driveshaft. (Front shaft is not in yet. Too short)
76 Regal with about 500 hp 3997 lbs 6.0 Liter LS/6l90e
2006 Jeep grand cherokee SRT8 450 hp AWD 4,788 lbs
2013 Jeep grand cherokee SRT about 530hp AWD 5,150 lbs
2008 Pontiac G8GT 475hp 3,995 lbs
Old 04-16-2025, 11:23 AM   #169
bambbrose
bambbrose's Avatar
Would love to see some videos of this thing going down the road!
Restoring a 1972 K5 CST Highlander, White on Parchment w/ Black Top
Restoration Diary
Current WTB Thread https://67-72chevytrucks.com/vboard/...d.php?t=856079
bambbrose is offline   Reply With Quote
Old 04-16-2025, 11:25 AM   #170
NDM
I will make it happen today. Just gotta get my tripod after work.
Old 04-16-2025, 11:42 AM   #171
Badride76
Badride76's Avatar
I want to see pics and video of this please...... 76 Regal with about 500 hp 3997 lbs 6.0 Liter LS/6l90e!!! I had a 77 Regal in high school.
Badride76 is offline   Reply With Quote
Old 04-16-2025, 12:43 PM   #172
NDM
Yup. I will get something today. I just took a co-worker on a short rip. It is very violent. He texted our boss that he was going to need to file paperwork for his on the job incident.
Old 04-16-2025, 09:20 PM   #173
NDM
Good news- I did not break a driveshaft.
Bad news-I broke a u-joint and am waiting on a tow truck!
Good news- I have a posi and can leave rubber on the ground.
Bad news- major wheel hop makes my wheel rings fly off.
Good news- I captured the annihilated joint experience on video.
Bad news- you may never get to see the video.
Good news- I think I will be able to repair it quickly
Here's a couple pics though! I should be driving again tomorrow. No more burnouts until I get a stout driveline.
Old 04-17-2025, 01:22 AM   #174
NDM
I would like to add to my Good news bad news story. Everything happens for a reason. So the timing of this was odd. The moments that happened leading me here where I sit at the hospital. I had a fantastic day at work which was weird. I had a great time in the process of breaking my truck. The tow truck took too long but it is ok. Due the way that time worked out, I was about to pay the tow truck guy when my neighbor stopped me to ask me to come to his house. He is a veteran from a generation before me. It was weird and I walked over and he asked me for help.
I listened. We called the suicide prevention hotline. They listened.
So, here I sit with him. He is getting the help that he needs. He was so worried about my time. I told him that time does not exist tonight.
My message to you all. If you are given the honor of being trusted enough to help someone....please do not pass up the opportunity to earn your good karma. I believe that we all will be placed at a crossroad to help someone. Some of us will be placed there many times. I am thrilled that whomever or whatever it is that controls our destiny has trusted me with this responsibility. My broken truck does not matter. Nothing else matters. What matters is that this old Marine trusted me, a much younger Airforce guy with his deepest struggle. The fact that we are veterans does not matter. He is in need. I had a fantastic day today. I was put exactly where I needed to be to provide that help. I was a bit frightened. I still am. But I used my mind and heart to do the best that I can for him in his crisis.
Please be good to each other. No matter the color, the weight, age or any other difference. I am not a saint. But one day I may need help too. We are all connected. Remember that.
Good night and for anyone that prays. Send one out to whomever you believe in to give this old guy a boost. Thank you.
Old 04-17-2025, 11:34 AM   #175
NDM
Austin_Jim said:
I have no words other than you are a stellar human. Prayers inbound
RedT131 said:
Thank you for taking the time to sit and listen to your neighbor in need. I'm certain it was difficult for him to ask for help. You were put in the proper place at the proper time. Kudos to you. Thank you again.
My Response-
That is the thing. I am not a "stellar human". I am a normal guy with seemingly more flaws than perfections. My message is that you do not have to be a stellar human to just be human. This man is three decades older than me. This man spent a year in a VA hospital recovering from a round from an AK47 while serving in Vietnam. He is a retired police officer and has served his country and his community for essentially my entire lifetime. It was an honor for me to put in a spot to be able to serve him. Even if he was not a Vet or an officer, he needed someone.
I deserve no kudos for something that I was supposed to do. But thank you. If you really want to thank me, please rise to the occasion if you are ever placed at a similar crossroad. Listen to the soul of the person. Ignore your fear and take a chance at doing the right thing. You may one day need help too.
