'74 Audio upgrade
I've always liked a good audio system, car and home.
The 74 has the factory AM radio. I am leaving it because I won't cut the dash. Plan is to add a Bluetooth adapter and directly feed my 4 channel amp. 2 channels will power a set of 6x9 component speakers, and the other two channels bridged to run a sub. I purchased a set of metal mounts from 73-87.com for the 6x9 that fit into the corner behind the seat . They seem very well made, and made in USA which is important to me. I painted them, and will add a layer of deadening mat before installing into corners. Built a sub box to fit behind the seat today. Using a shallow sub from infinity. Seat will go all the way back. |
Re: '74 Audio upgrade
Here's a few pics.
Made more progress the other day after work.
Carpeted the sub box, added deadener and carpet to the 6x9 corner adapter plates. Last edited by Shark_13; 03-23-2025 at 11:55 AM. |
78 Big10 454
![]() Join Date: Jul 2008
Looking sharp. Nice, clean installation.
1978 Chevy SWB C-10 2WD 454/400 |
Thanks!
Plan is to keep it completely "stealth", nothing visible. Amp, crossover and Bluetooth adapter will all be under seat on floor. After I recover the seat, I hope to modify it to make it fold forward. Then I can use the space beside the sub box for a little bit of storage too |
Here's the rough layout.
Got the carpet removed, power run to the battery, passenger 6x9 in. After work this week should be able to finish it up wiring. |
Nice work on the sound system and congrats on the overall purchase and work on the truck so far.
It's finished except for tweeters. Haven't found their final spot yet.
Rockford Bluetooth adapter works pretty slick, stream directly to amp. |
Tweeters sound pretty good down on the kick panels.
Bonus I used the existing panel mounting screw so it worked out well Put a couple acdc albums through it today. Needs a little tuning still but pretty good. |
| Bookmarks |
