Old 03-31-2025, 07:34 PM   #1
raidmagic
raidmagic's Avatar
1965 deluxe dash question
Anyone know of gauges that fit this that will work with electrical guages? I just picked this up and would like to make that work. The oil pressure is the only one that appears mechanical but I don't know what sending unit the temp guage would need. I'm using Autometer right now.
1965 C-10 1/2 ton shortbed part time daily driver
1980 C-10 1/2 ton shortbed project
raidmagic is offline   Reply With Quote
Old 04-01-2025, 11:36 AM   #2
rideblue00
rideblue00's Avatar
Re: 1965 deluxe dash question
What is it, no picture...
rideblue00 is offline   Reply With Quote
Old 04-02-2025, 06:07 PM   #3
raidmagic
raidmagic's Avatar
Strange, picture shows for me. It's the deluxe dash with water,oil,volts gauges in it instead of dummy lights.
Old 04-03-2025, 09:54 AM   #4
scottofksu
scottofksu's Avatar
I wonder if you could use an I/P Converter (https://www.westlockcontrols.com/i-p-converter/) to take the signal from your sending unit and convert it to a commensurate amount of fluid pressure to make the gauge work...
Travis' Tribute Truck - 65 C10 Frame Up Restoration
http://67-72chevytrucks.com/vboard/s...d.php?t=495073
scottofksu is offline   Reply With Quote
