Old 07-23-2013, 10:21 PM   #26
amcgeh01
amcgeh01's Avatar
Re: How To Remove The Lock Cylinder From A Blazer Hatch Handle
Check here, it may help depending on what step you are on...
http://67-72chevytrucks.com/vboard/s...=hatch+drawing
Originally Posted by TRUCKRUNNER67 View Post
How do u get the handle out of the top
In-work on my 5.3L/4L65E/NP208 case conversion into a 1972 GMC JImmy 4x4... Not as simple as it looks folks..
amcgeh01 is offline   Reply With Quote
Old 01-22-2015, 05:06 PM   #27
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Good information...
D.PASSMORE is offline   Reply With Quote
Old 08-14-2017, 04:53 PM   #28
whitetailbob
just wondering if the square stock of the handle is able to be pulled out of handle and a new piece installed...thanks
whitetailbob is offline   Reply With Quote
Old 08-14-2017, 10:01 PM   #29
1rippen6
Not easily, it is casted into the handle. I've done it before but I used a lathe, drill press, and dremel tool in that order.
1rippen6 is offline   Reply With Quote
Old 08-14-2017, 10:33 PM   #30
whitetailbob
i thought it was cast around it thank you very much!
Old 08-15-2017, 06:57 AM   #31
jjzepplin
jjzepplin's Avatar
Good info here! So say I am able to get my original out of my hatch. Then I am able to get the cylinder out. Now - I need a key. Where do I find one?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 08-15-2017, 07:12 AM   #32
1rippen6
The original poster LockDoc. If you send him one of your keys he can match it so the same key works the doors and handle.
Old 08-15-2017, 10:37 AM   #33
DeadheadNM
Carpe manana
DeadheadNM's Avatar
LockDoc just keyed a handle for me last week. Big thanks! I've got the handle out to be re-chromed right now.
Old 08-15-2017, 12:21 PM   #34
jjzepplin
jjzepplin's Avatar
I kinda figured he could do it. Thanks. I didn't know a door key was used. Guess I never tried one. Thought it was one of those mailbox sort of keys.
Old 08-15-2017, 12:33 PM   #35
1rippen6
That may be the case but the door key will work.
Old 08-15-2017, 12:56 PM   #36
1rippen6
Actually last year I bought an NOS hatch lock assembly off ebay and it had a square key like the ignition. I believe so anyhow I will have to dig it out and take a look.
Old 08-15-2017, 01:27 PM   #37
jjzepplin
jjzepplin's Avatar
Going to try some keys...
Old 08-15-2017, 01:32 PM   #38
jjzepplin
jjzepplin's Avatar
Just tried several door keys and sum mutha- wait for it- they fit but no deal.
Old 02-26-2018, 11:16 PM   #39
robs71k5
K5drive
robs71k5's Avatar
When it comes to making the square stock that fits over your handle . I was able to find a company that sells this stock . If comes in two or three inch lengths and only 1/2 inch diameter . I was able to machine down a piece of pipe with inside diameter 1/2 inch and outside diameter I had to machine down to look like the original part with a 'c' clip grove for reassembly . Once it was machined down I merely welded the square hole shaft to the new piece of pipe already machined down . The picture below is what the part I machined looks like that fits over the square holed shaft looks like . Again can also be done on drill press if patient . If having trouble email he at srpenner@hotmail.com
robs71k5 is offline   Reply With Quote
Old 02-26-2018, 11:31 PM   #40
robs71k5
K5drive
robs71k5's Avatar
The square stock and the pipe pictured below was able to build a couple parts and have a spare for sale . The square stock was not cheap (about $75) but if your wanting your build to closely resemble the original part then this is your best coarse of action .
Old 02-26-2018, 11:32 PM   #41
robs71k5
K5drive
robs71k5's Avatar
Assembled
Old 08-09-2018, 04:37 PM   #42
NorthernMatthew
NorthernMatthew's Avatar
I'm adding myself onto this very useful thread, thanks Leon.
NorthernMatthew is offline   Reply With Quote
Old 11-24-2019, 01:17 PM   #43
jjzepplin
jjzepplin's Avatar
OK. So mine was stuck all kinds of ways. I sheared the pin off at the end of the cylinder. Is there any way to fix this or do I just need another one? Any body got one?
Old 12-02-2019, 11:11 AM   #44
CHEVY_DUDE
CHEVY_DUDE's Avatar
Did the handle use the same key as the doors and ignition? Or was it a completely different type of key? Mine came with the original handle, but no key that worked.
1962 Chevy II Nova 400 Sport Coupe
1962 Chevy II Nova 400 Station Wagon
1972 GMC Jimmy
CHEVY_DUDE is offline   Reply With Quote
Old 12-02-2019, 11:38 AM   #45
pound41
yes ignition and door key works mine
pound41 is offline   Reply With Quote
Old 01-15-2020, 10:21 AM   #46
69TowRig
I wish this thread existed in the mid-2000's when I bought mine. I pitched that handle and replaced it with a garage door unit. Now I wish I had the original handle back!
-Chris
Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid.
Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals...
69TowRig is offline   Reply With Quote
Old 04-02-2025, 01:10 PM   #47
HOTFUN
HOTFUN's Avatar
subscribed
'66 CST BBW swb fleet 327 fac ac
'67 CST 4x4 swb 327 factory #'s V8 stepside project
'72 Cheyenne K20 50k original
'72 CST Blazer K5 owned 30+yrs
'73 Sierra swb 4x4
'74 Cheyenne Super swb w/16k actual
'71 & 72 Cheyenne K10 4x4 swb's
'70 426 HEMICUDA conv SHAKER 4 sp Dana 60
'60 Impala conv 3rd owner
'72 GMC K2500 4x4
'59 Apache CST BBW fleetside swb 283
'73 ElCamino SS LS1 T56 true SS bucket tach
'76 ElCamino SS 52k survivor
'87 Grand National 41k True 2nd to last built in 1987.
'86 K30 454 SRW fleetside CA since new
'88 Trans Am GTA 39k bought new
2018 DEMON plum crazy @ 840HP! "Need for speed"
HOTFUN is offline   Reply With Quote
