Old 03-16-2025, 03:49 PM   #1
Nick_R_23
Nick_R_23's Avatar
1965 C10 Shortbed Fleetside
I scored this 1965 C10 Short bed fleetside yesterday for $500! It’s rusty and beat up, but complete. It appears to have a 230/6 and powerglide. No idea if it runs or even turns over at this point, I was told it was parked a long time ago, the owner passed away, and nobody knows why the truck was parked. I think the tags expired in 2001. I’m not really sure what I want to do with it yet, but I may try to get it running and fix some rust and damage, and lower it.
This is after getting home last night around midnight through a three hour drive and a snowstorm!
Old 03-17-2025, 12:51 AM   #2
Nick_R_23
Nick_R_23's Avatar
Re: 1965 C10 Shortbed Fleetside
I threw on an extra set of hubcaps I had around. It looks a bit better anyway!
This is the interior - with custom switches!
I messed around with it a bit today, the starter solenoid was junk, so I replaced it with one I had off another bad starter. The engine cranks well, I cleaned the points and poured some gas down the carb. After a bit of fighting, it finally fired up and somewhat idled for a bit until it ran out of fuel. It definitely needs a carb kit, but at least the engine might be good!
Old 03-17-2025, 09:20 AM   #3
rbruno68
Can't say I have ever seen electrical switches used in a car/truck. That is different. Glad it ran for a bit.
rbruno68 is offline   Reply With Quote
Old 03-18-2025, 07:15 PM   #4
Nick_R_23
Nick_R_23's Avatar
There’s a new carb kit in the glove box, so I’m going to try to use that to rebuild the carb. I also ordered an AAW ignition switch with a new connector, a new key cylinder, and a new HEI distributor. Hopefully between all that, I can make it start and run without too many issues.
Old 03-24-2025, 11:09 PM   #5
Nick_R_23
Nick_R_23's Avatar
Key switch assembly showed up today!
Old 03-26-2025, 03:59 PM   #6
Nick_R_23
Nick_R_23's Avatar
The weather crested into the 40’s this week, so I took advantage of the nicer weather and pressure washed 25+ years of grime off the truck
Old 03-26-2025, 08:28 PM   #7
DPowers
One foot in front of the other
DPowers's Avatar
Very Cool. Congrats
DPowers is online now   Reply With Quote
Old 04-04-2025, 01:12 AM   #8
Nick_R_23
Nick_R_23's Avatar
I scored a set of M1009 wheels today! 6 lug, deeper offset, clears disc brakes, 15x8, and accepts hubcaps.
Old 04-04-2025, 11:08 AM   #9
rbruno68
That is a great score. I am starting to like steelies and caps more and more. I have ralleys now, but am thinking I might clean them up and sell to get steelies. If I can find some good hubcaps, I definitely will.
Old 04-05-2025, 12:03 AM   #10
Nick_R_23
Nick_R_23's Avatar
Even better was they were only $150!
New HEI distributor showed up today, got a full tuneup ready.
Old 04-07-2025, 01:46 AM   #11
Nick_R_23
Nick_R_23's Avatar
Started on the tune up today and ended up jumping around on a few different things. Started off with changing the oil and filter. Distributor removal made that easy.
Block numbers if anyone cares to decode them.
New spark plugs, also redid the harness and changed out the resistor wire to a standard wire for the HEI.
New distributor and wires installed.
Repinned the key switch plug
Ignition installed! The engine cranks with the key now!
I also pulled the carb off for a rebuild, but the kit I had with the truck was incorrect. I ordered the correct carb kit which should be here tomorrow.
Old 04-07-2025, 03:18 AM   #12
Braunschweiger
Good work,
I'm excited to see what the truck looks like in the end.
Greetings Harald
Greetings Harald
My 62 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=829782
Braunschweiger is offline   Reply With Quote
Old 04-14-2025, 01:05 PM   #13
Nick_R_23
Nick_R_23's Avatar
The carb was missing the filter and definitely due for a rebuild. It would be cool to try out the Sniper 1100 on this, but we’ll see how the carb does for now!
Picked up a new radiator cap as well as a fuel cap.
Old 04-14-2025, 02:15 PM   #14
Nick_R_23
Nick_R_23's Avatar
Hopefully these work. I took a video of the truck running after the HEI conversion and carb rebuild. It’s not tuned as of yet, and the exhaust gasket is leaking, but it’s idling pretty well! The truck would try to reverse when I revved the engine up, so I had to adjust the linkage to make Park actually be Park.
http://www.youtube.com/watch?v=E9zBGg5miEU
I topped off the transmission fluid and took it for a quick spin down the block!
http://www.youtube.com/watch?v=v90jaTMqXyM
Old 04-15-2025, 02:27 AM   #15
Nick_R_23
Nick_R_23's Avatar
I started to replace the blown out exhaust gasket today. Manifolds came off surprisingly smoothly.
Failed gasket
I figured I was going to have trouble with a few of the studs, however, I didn’t anticipate a chunk of the exhaust manifold being broken off. I have a new one on order.
Old 04-15-2025, 04:15 PM   #16
TJ's Chevy
TJ's Chevy's Avatar
Congrats on the find for that cheap! In my part of Oregon that's just about unheard of now a days.
There's something about getting an old truck, cleaning it, and making it run that just makes the soul happy.
I've gotta find my book but I could probably decode the I6 for ya. If it's a 250 they make some pretty cool hotrod parts for them.
I upgraded my 292 a little haha
Old 04-15-2025, 10:00 PM   #17
SkinnyG
SkinnyG's Avatar
What part is broken off? Isn't that just the heat stove for the carburetor? It should just seal up against the bottom of the intake manifold, no??
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 04-15-2025, 10:31 PM   #18
bsarts
bsarts's Avatar
I'm glad you're saving her, she'll be a beauty!
bsarts is offline   Reply With Quote
Old 04-15-2025, 11:18 PM   #19
Nick_R_23
Nick_R_23's Avatar
Thanks guys!
It’s hard to tell from the pic, as it appears to have been broken off for a while due to the rust, but the third bolt hole opposite the two studs is completely broken off.
Old 05-04-2025, 02:28 PM   #20
Nick_R_23
Nick_R_23's Avatar
The new exhaust manifold showed up yesterday. It’s definitely a rough Chinese casting, but for an inline 6 it should do the job.
Test fitting
Manifold loosely mounted to the block
Carb manifold reinstalled! It runs much quieter with the leaks fixed.
Old 05-05-2025, 06:25 PM   #21
shp4man
shp4man's Avatar
I've got one of those Chinese exhaust manifolds on my truck So far, so good at over 10,000 miles.
Wish my truck was a Powerglide. I'm lazy.
Everybody has to believe in something. I believe I'll have another beer.
shp4man is offline   Reply With Quote
Old 05-17-2025, 11:39 PM   #22
Nick_R_23
Nick_R_23's Avatar
I found a good set of tires for really cheap, just to get this thing back on solid rubber that holds air and stays drivable. Pulled the wheels off.
Ultimately, I think I want to paint the 15x8 wheels white, but I’m curious what the red would look like, so I spray painted these red to try out the look. I’ll be getting the new tires mounted Monday.
Old 05-20-2025, 01:13 AM   #23
Nick_R_23
Nick_R_23's Avatar
I got the new tires installed today!
Cleaned up the white walls
Wheels installed!
Hubcaps installed!
Old 07-10-2025, 03:01 AM   #24
Nick_R_23
Nick_R_23's Avatar
I sold the topper today for $80! The truck looks so much better without it!
I also picked up some extra parts I think I forgot to post. Two core supports, a grille, and a pair of doors!
Old 08-11-2025, 07:09 PM   #25
Nick_R_23
Nick_R_23's Avatar
Last night I sold the 230/6 and powerglide for $500, so right now the truck itself was free! I found a cab that got crushed, but the lower side seems to be in good shape, so I might try to get that picked up and grafted onto mine.
I’m considering my engine and transmission options now.
