Pic Request
This is for a 1975 model GMC/Chevy 1/2 ton.
Can someone take a pic of their wiper motor for me? Specifically the 3 mounting bolts with the rubber isolators. I want to see the location of the grounding strap that is made into 1 of the rubber isolators and where it is attached to the aluminum frame of the wiper motor assembly. Many Thanks! |
Re: Pic Request
Edit.
Re: Pic Request
anyone?
![]() Join Date: Feb 2000
Re: Pic Request
Here ya go
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
Re: Pic Request
You are probably looking for pictures of the factory ground grommet that has the 2-1/4" long copper ground strap.
It would be nice to know what the factory part number is for this grommet?
Stock 75 C10 step side. 350 2 BBL, 350 trans. 150K miles. |
Re: Pic Request
I can see the picture I posted, is it not showing up for others? The grommet part number is 22009636, 4911142 is the grommet without ground strap.
Re: Pic Request
I see some wiper motor gromets on ebay and LMC that have a ground strap that looks to be 1-1/2" long. I guess you could solder on a copper extension on to make it long enough.
Re: Pic Request
MJN thanks for the part numbers.
A picture from my 75.
Re: Pic Request
Thank you gents! Do NOT buy the kit from LMC as the brass ground tab is too short. Just a FYI ...
Re: Pic Request
Wiper /pump runs fitments other info. The longer ground is 73-77 only.
https://bowtieguy.proboards.com/thre...-washer-repair
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bedWas a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
| Bookmarks |
