Old 04-06-2025, 09:24 AM   #1
1964FarmFreshC10
1964 C10 3 Speed Backup Lamps
I'm looking to install backup lamps on my 1964 C10 3 Speed.
After doing a bunch of searching i found where the switch is supposed to be located on the steering column.
Is the tab that contacts the switch supposed to be more centered in the opening or does this look correct?
Thanks for any help you can give!
1964FarmFreshC10 is online now   Reply With Quote
Old 04-08-2025, 12:43 AM   #2
val1gonzales
Re: 1964 C10 3 Speed Backup Lamps
Do a search up top on this site for some possible images. This looks similar:https://lugnutz65chevystepside.weebl...n-rebuild.html
val1gonzales is offline   Reply With Quote
Old 04-08-2025, 08:25 AM   #3
1964FarmFreshC10
Thanks 😊
