Old 02-18-2022, 05:13 PM   #26
dsraven
Re: Mark's 51 Build
You could make a cardboard pattern and hang it in place with magnets or duct tape. Come up with what looks good whether it is 1, 2 or 3 pieces. Then fab it up out of 16 or 18ga cold rolled sheet. Make it a little big so you can finish the edges if you like.
Old 02-18-2022, 05:32 PM   #27
Tempest67
Tempest67's Avatar
Re: Mark's 51 Build
Use some 18 gauge metal and make an apron. If I remember, there are several bolts located under the grill you can use to attach it with.
Also, I liked your steering wheel center idea so much, I put it on mine. Thanks
Tempest67 is offline   Reply With Quote
Old 07-22-2024, 09:40 PM   #28
edgeleycanuck
Re: Mark's 51 Build
I was asked about frame pictures and wheel spacing.
I really regret to say the best photo shot of the frame was posted
The wheels are just 15" American racing wheels. I went to a local wheel shop with measurements from mounting surface to fender lip and he ordered based on that. I really don't have record of the wheel specifications. It was dumb of me not to document more of what I did, however the dakota chassis does not garner much interest.
edgeleycanuck is offline   Reply With Quote
Old 04-13-2025, 11:59 AM   #29
edgeleycanuck
Re: Mark's 51 Build
I'm starting another AD truck. This will also use a Dakota chassis. I want to use a 292 engine with standard transmission. What I'm hoping for some feedback on is a clutch and brake pedal assembly solution. Has anybody reworked a clutch/brake under dash pedal assembly into one of these trucks? Planning on a hydraulic clutch. Thanks.
