Old 04-02-2025, 08:01 PM   #1
b-mac
b-mac's Avatar
49 gauges - stud size?
Hey guys.
I rebuilt my gauges and I want to do a write-up, but I'm stuck.
What size is the darn stud on the back of the dash that holds the gauges in.
Mine were carefully stored a decade ago. If I could only remember where...
b-mac is offline   Reply With Quote
Old 04-04-2025, 03:17 AM   #2
mr48chev
mr48chev's Avatar
Re: 49 gauges - stud size?
I'm thinking 12 32 but may be wrong. I don't know what I did with the nuts off the speedometer when I pulled it out of the 51 cab I have out here but I'd still have to run a tap through one to figure it out as my eyeball measuring device isn't what it was 40 years ago.
My ongoing truck projects:
Old 04-04-2025, 01:05 PM   #3
e015475
e015475's Avatar
IIRC the studs on my 49 gauges took a 10-32 nut
12-32 is certainly a possibility, but the only place I've ever seen that thread pitch is on a firearm. Strangly enough, I believe I have a tap and die in that size (inherited from my FIL)
e015475 is offline   Reply With Quote
Old 04-04-2025, 11:48 PM   #4
mr48chev
mr48chev's Avatar
10 32 may well be correct, I went out and looked last night couldn't find any of the nuts.
Old 04-05-2025, 01:23 AM   #5
leegreen
I think 10-24
here is a picture of a dash modification where you can see one and it does not look like fine thread to me.
leegreen is offline   Reply With Quote
Old 04-05-2025, 10:17 AM   #6
MARTINSR
MARTINSR's Avatar
First thing I have to say is GET A THREAD GUAGE!!!! They cost a few dollars and they will save your butt often.
Second, if you are building old cars and trucks GET A TAP AND DIE SET!
Ok, I just went out and checked mine. First photo you see how anal I am. The studs were all wrapped in masking tape so they don't get filled up with primer. LOL
I checked it with a tread gauge and it's 32 threads per inch.
I couldn't find a 10-32 nut so I used the 10-32 die and it spun on like a new nut and stud. Which is why I cover them so they don't get primer or paint on them.
Anyway, yes, it's a 10-32.
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 04-05-2025, 11:08 AM   #7
MARTINSR
MARTINSR's Avatar
Honestly guys, get a tap and die set. I use it VERY often cleaning threads before putting a nut on. Or running a tap into a fixed nut so the screw or bolt goes perfectly into it.
On old cars and trucks it's so useful, instead of messing up threads worse forcing a nut on bolt, it cleans the threads up to perfection so the nut or bolt just rolls on with love.
Get one, they are as cheap as $10 for SAE only or a few hundred $ if you want an awesome complete kit for everything you could ever work on.
Brian
1948 Chevy pickup
Old 04-06-2025, 11:03 AM   #8
crossfire84
crossfire84's Avatar
what he said!!👆
LIL ERV the 50-3600
396 BBC stroked to 415 cid
Richmond 6spd over drive
C4 rear
Porter built a arms
Never give the Devil a ride,because he'll want to Drive!
crossfire84 is offline   Reply With Quote
Old 04-14-2025, 12:55 AM   #9
b-mac
b-mac's Avatar
Thanks men!
My cheap-o Harbor Freight tap and die set let me down on this one.
It's sparse under 1/4".
I posted a ton of pictures of my gauge rebuild in a different thread.
I think it turned out pretty good.
Old 04-14-2025, 12:57 AM   #10
b-mac
b-mac's Avatar
Actually, MARTINSR, I forgot all about the little key in there for smaller sizes. Thanks again!
Old 04-14-2025, 11:05 AM   #11
MARTINSR
MARTINSR's Avatar
Right on!
Brian
1948 Chevy pickup
