Old 08-29-2004, 03:49 PM   #1
ChevyDude
Front ball joint question/ help please
I am changing out the front spindals and springs, going with ECE 2.5" drops and Ground Force 2" drop springs. I've got the springs out and the spindals off and was wondering is there anyway to change out all the rubber around the ball joints? Should I replace the ball joints on the upper and lower control arms? If so how do you remove the ball joints, aren't those big rivets? I want to put new rubber between the tie rods and sway bar,,,where should I buy it? I am going to have the control arms soda blasted so maybe it would be a good time to replace the ball joints or if I can just replace the rubber bag that holds the greese??? Any help would be greatly appreciated!!!
Alex
1971 Lil' Red 350 SBC 700R4
ChevyDude is offline   Reply With Quote
Old 08-29-2004, 09:01 PM   #2
Sweet72
Sweet72's Avatar
I'd replace 'em now if you still have the orig. riveted on uppers. Just drill out the rivet head and punch the rivets out. On the lower ball joint, have a auto machine shop press them out if you don't want to buy the removal and installation kit. The replacement upper comes with four bolts to replace the rivets and the new lowers will have to be pressed in. Good luck...
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 08-29-2004, 10:39 PM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
If you're going to have the arms blasted, deifinitely replace them. The blast media will infiltrate the joint and cause real, real rapid wear.
Sweet gave you the straight skinny on replacing them.
Only thing I'd offer on that is that drilling the rivets out on the old upper ball joints has never really worked very well for me. I use an electric angle grinder to grind the heads of the rivets off and punch the shanks out.
If you don't have a grinder, you can pay anywhere from 15 dollars to 100 dollars. The cheap ones seem to work pretty well for most casual hobbiests. I got several years of hard work, like building trailers, out of my first 15 dollar cheapie before I replaced it with a good'n.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 08-30-2004, 12:29 AM   #4
Sublvr72
Sublvr72's Avatar
agreed, replace the ball joints while you have access to them, grind off the rivets and bolt a new one in. the lower has to be pressed out and you press a new one in.
Sublvr72 is offline   Reply With Quote
