#276 |
Re: Lss3
I installed the Mar-K hidden latches. Drilling all the holes and cutting the slots was tricky. I made a wooded jig to position the 5/8” hole. I didn’t want the hole saw to wander. A couple of wedges and a C clamp held the jig in place.
#277 |
Re: Lss3
More work on the circuit breaker panel. I made a cover out of Delrin to protect the copper bus bar. I didn’t want a tool to be able to short the battery to ground.
#278 |
Re: Lss3
Just saw this build, 5 months since the last post, time for an update!!
70 C20 Build link : Project Montezuma http://67-72chevytrucks.com/vboard/s...d.php?t=794479 How to repair that rusted out 67-72 c10-c30! Please subscribe! https://www.youtube.com/c/MaycoCustomRestorations |
#279 |
Re: Lss3
You are absolutely right that I should do an update, but I haven't accomplished much lately. My goal is to get the electrical panel installed and the wiring hooked back up so I can start it again. Wish me luck.
#280 |
Re: Lss3
For three Christmases in a row, I have gotten parts for the bed. First were new bed sides. The next year was the tailgate. This year I got wheel tubs from DAN CARPENTER'S SPECIALTIES. My wheels just barely fit without the tubs. They might rub going around corners. There would be no room for larger wheels without the addition of the tubs. The time to add tubs is before paint.
#281 |
Re: Lss3
Those are some fancy tubs!
#282 |
Re: Lss3
Great build. I enjoyed reading though it. Great fab work.
________________________________ 1972 SWB stepside pro tour build thread http://67-72chevytrucks.com/vboard/s...d.php?t=452840 |
#283 |
Re: Lss3
Added notches to the tailgate for the MarK stainless steel links. Before cutting, I added plug welds every 2 inches along the cut line since many of the original spot weld get removed by the notches.
#284 |
Re: Lss3
Here is my electrical panel mounted to the radiator support. Things are a bit dusty.
#285 |
Re: Lss3
The next project is the cooling system. The fan just arrived from Delta PAG.
https://deltapag.com/products/18-brushless-fan-kit I should be putting together the shroud in the next couple of days. |
#286 |
![]() Join Date: Oct 2012
Re: Lss3
Sub'd to follow along for the remainder of the build. Just read through the thread, love all the small details you've done. Good job!
Scott 1970 C10 Restomod|454/700R4|LWB-->SWB Build Thread 2014 2500HD DirtyMax|Daily Driver|Stock 2003 Tahoe Stock 1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed |
#287 |
Re: Lss3
Here is a picture of the fan and parts to make a shroud. There are a lot of reasons to use the Delta PAG. It is the biggest fan that will fit, 18 inches. It is brushless so there be less wear and heat. The power circuits mount externally, so the motor is smaller and blocks less air. It is variable speed which will allow it to run at an optimum speed, making it quieter. The controller makes setting and changing it easy.
| Bookmarks |
