Old 11-27-2015, 05:04 PM   #1
crazychevyc10
what steering columns are direct fit?
hey guys - I have a 68' and wanted to know what year steering columns are direct fit?
thanks!
crazychevyc10 is offline   Reply With Quote
Old 11-27-2015, 05:26 PM   #2
68Gold/white
Re: what steering columns are direct fit?
I don't have all the answers, but the 67-72 pickups interchange. Chevrolet/GMC full size vans that have the ignition switch in the dash will also interchange.
The vans had the ign switch in the dash for many years after 1972.
I don't know what year the vans started using the ign switch in the column.
These are the only "for sure" direct fit columns I know of....
68Gold/white is offline   Reply With Quote
Old 11-27-2015, 08:09 PM   #3
BCOWANWHEELS
isn't a van column longer
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 11-27-2015, 09:38 PM   #4
hugger6933
The only direct fit is the truck tilt but a van tilt up to 82 or a motor home tilt up to 85 will work. thew motor home tilt looks closer to the truck tilt in my opinion but look at the FAQ section for our models as there is a ton and a half of write ups on how to make a van tilt work in our trucks.
On a side note I took a van tilt that had a wallowed out shifter pin hole and worked on it by grinding off the humps filling the holes that left and fixed up a column that looks like a factory tilt for floor shifter. It looks real slick. Jim
hugger6933 is offline   Reply With Quote
Old 11-28-2015, 10:03 AM   #5
67/68s are different from 69-72. In '69 they went to collapsible, so you need everything from the steering box-up. Van columns are longer, but have enough "collapse" to them that you can shrink to fit. GM p-chassis vehicles (StepVan/motor home) also work. You want ones with no ignition in the column
Old 11-28-2015, 10:14 AM   #6
EARNHARDT#3
EARNHARDT#3's Avatar
My '67 is collapsible as well.
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP
EARNHARDT#3 is offline   Reply With Quote
Old 01-03-2016, 09:43 PM   #7
57larry
how do tell a 67-68 steering shaft from a 69-72? pics from a collapsible & non-collapsible please. thanks, Larry
57larry is offline   Reply With Quote
Old 01-03-2016, 11:12 PM   #8
Possmguts
Possmguts's Avatar
Collapsible? Whats that all about?
"Hey... its only time and money right? Just do it."
67 Short Bed under major construction
http://67-72chevytrucks.com/vboard/s...=651356&page=8
Possmguts is offline   Reply With Quote
Old 01-04-2016, 07:14 AM   #9
Aus69c20
Aus69c20's Avatar
a collapsible column will collapse in a front end collision. Non collapsible column will spear the shaft and steering wheel into you if the collision is serious enough.
At least that is my understanding.
John
69 c20, 396, th400, dana60, ps, ac
Aus69c20 is offline   Reply With Quote
Old 01-04-2016, 08:19 AM   #10
30 a truck
30 a truck's Avatar
Collapsible has 2 plastic "pins" holding the double d in place. Upon impact, they shear allowing the shaft to slide inside itself.
30 a truck is offline   Reply With Quote
Old 01-04-2016, 01:03 PM   #11
FirstOwner69
FirstOwner69's Avatar
To clarify the information in the above posts, the steering column itself is not collapsible. The intermediate shaft is collapsible. The thread linked below provides more info. Also, as noted above, this was a safety feature to reduce the risk of the column spearing the driver in a frontend collision, and the intermediate shafts in the 67s and 68s were one piece.
http://67-72chevytrucks.com/vboard/s...d.php?t=309895
FirstOwner69 is offline   Reply With Quote
Old 06-06-2018, 12:35 AM   #12
crakarjax
crakarjax's Avatar
My 68 came with a collapsible shaft as well; both 1 piece and 2 piece shafts are collapsible.
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 04-16-2025, 09:13 PM   #13
Brent1990
Not trying to take over this thread but does anybody have a picture of a 68 GMC emissions sticker
Brent1990 is offline   Reply With Quote
Old 04-17-2025, 02:43 PM   #14
crazyjeenyus
crazyjeenyus's Avatar
'81 GMC van tilt column fits nicely in my '67 (it does have the ignition on the column).
'67 c10
'65 c10
crazyjeenyus is offline   Reply With Quote
Old 04-18-2025, 08:56 AM   #15
70STOVEBOLT
70STOVEBOLT's Avatar
You would be better off starting a new thread.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 04-18-2025, 09:57 AM   #16
dagnabbitt
dagnabbitt's Avatar
That's interesting! Did you do any modification at all, or did it bolt in?
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 04-21-2025, 01:35 PM   #17
crazyjeenyus
Bolted right in.
The steering wheel sits a little closer to my chest than the original setup did, but I'm not a big guy so it works better for me.
'67 c10
'65 c10
