Old 04-17-2025, 01:28 PM   #10
68isgreat
Re: Cardan joint on rear driveshaft? 71 K10
Originally Posted by Richard View Post
Raising the transmission will increase the working angle of the u-joint. Think you are confusing component angle with working angle. Say trans is at 4 down and drive shaft at 8 down. That is a 4 degree working angle. Raise the trans to 3 down, shaft will get steeper say 9 down. You have increased working angle to 6.
Great point. I can just leave my trans where it is at 4 down since it's tbi fuel injected, and put a 4 degree shim in the pinion to drop it down to say, 3 degrees to allow for upward wrap under load. If the working angles end up being more than 3-4 degrees (which seems possible considering my driveshaft is only 37.5"), I wonder if I should consider a double cardan slip yoke. I'll just have to find out when I finally get it on the road I guess. Hopefully this summer.
68isgreat is offline   Reply With Quote
