![]() Join Date: Mar 2023
Wiring problems
Hello, just finished up my new aaw
harness. Couple problems. Fist brake light in dash stays on unless unplugged from new master. 2nd.. front marker lights come on with brakes pushed Any feedback appreciated |
Re: Wiring problems
The brake light sounds like the switch is grounded . Try a continuity test on it .
The front markers could be a problem with the turn signal switch
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
#3 | |
Re: Wiring problems
I bought the new rebuilt tilt off a member, maybe I’ll give him a pm and see if he can think of anything. |
#4 | |
Re: Wiring problems
I went out and looked. If you push in the emergency flashers. They don’t work until you turn the blinker on. And front marker lights come on to when breaking. Turn flasher off, everything works fine. |
#5 | ||
Always on the hunt...
Re: Wiring problems
![]() http://67-72chevytrucks.com/vboard/s...d.php?t=798288 .
***For any return/past customers & friends*** Before sending of any funds, please wait for a confirmed total and instructions for sending as our payment account info has been changed as of Jan. 2023. Thanks... |
#6 | |
Re: Wiring problems
It’s all new stuff in the column so I’m hoping I luck out with something else I’m missing, if not I’ll be calling. |
![]() Join Date: Feb 2022
Re: Wiring problems
Re brake light. It is very likely the combo valve got tripped while bleeding the brakes. So your brakes are only working on one circuit. Likely front. You need to reset combo valve, lock the shuttle valve in the center position and bleed brakes with lock tool holding shuttle valve. Then reinstall brake warning switch on combo valve.
#8 | |
Re: Wiring problems
I’ll research what you replied. What’s a lock tool.? |
#9 | |
Re: Wiring problems
I’ll let you know what happens, but I think you’re right. I did the fronts , then the backs a few weeks later. I think that’s what it is. |
Re: Wiring problems
#11 | |
Re: Wiring problems
Thanks for the help… I already started getting grey hair, and these problems don’t help. |
Re: Wiring problems
Member reached out to me thinking it the switch, and willing to send new one,
Or send column back for repair.. better service than any commercial seller. Must appreciate Don D… |
Re: Wiring problems
It's when you start loosing your hair from pulling it out you need to worry. Glad the brake light solution was simple.
| Bookmarks |
