Any carb recommendations?
Besides installing efi does anyone have a brand of carburetor that they prefer?
I have a 1984 c10 with a 305. It used to stumble quite a bit in cold weather until warm, now it stumbles no matter the temperature and seems to have a dead spot at around 1/4 throttle. It's starting to get a bit annoying and I have to really wait until the coast is clear or it could die altogether when pulling out. Any recommendations will be appreciated! |
Re: Any carb recommendations?
Rebuild the carb.
Yeah I thought about that but at 40+ years old she's pretty worn out.
I want something fresh and tight... (carburetor) |
Thank you I appreciate it and will check them out!
Robert Olson Transport
![]() Join Date: Oct 2002
If you go the aftermarket route, the last time i bought carbs i had three in a row from Edelbrock that were bad.. i bought a holley and havent had a problem since
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
Wow, that's good to know.
Thank you sir. |
I am no expert but if the throttle shafts are not loose then just rebuild it. Just grab hold of the throttle linkage and see if it has some play if so then get a newish one. These carbs are not hard to rebuild usually just need cleaned and new gaskets.
79 Chevy 2wd BIG10 350 TH400 |
Mine is pretty worn that's why I've decided not to rebuild it.
I think it's time for a new carb. |
I think I'm going to give this guy a shot, it's more in my price range.
Anyone had any interactions with them? https://www.guaranteedcarburetors.co...olet-gmc-truck |
Never heard of them.
What’s their price with no core? You definitely need to keep the carb you have. |
$289.00 without a core.
Could be the best 50 bucks you spent on your truck.
Another thought!
What transmission do you have? |
#15 |
700 auto
#16 |
That carb in the link doesn’t have the right trans tv cable hook up.
Without the right linkage you could fry your trans. Linkage adaptors are available but cost near 300 bucks. Getting a lot easier to just rebuild the one you have. |
#17 |
I'll make sure I have it all together.
#18 |
My Dad bought an 85 C10 brand new and it had the worst hesitation I have ever seen in a vehicle. It would fall on it's face if you tried to pass a car. Nobody could figure it out back then. I would be looking for a non-feedback carb and a vacuum distributor if it was mine.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
#19 |
![]() Join Date: Aug 2016
I ended up buying a knockoff Weber 32/36 2 barrel for the 69 in my shop, ended up going a different route and since rebuilding the 2-jet Rochester didn't work I put it on the 77 I've been working on. It works great and I see a little bit of improved MPG range with it.
| Bookmarks |
