Old 05-11-2025, 10:40 AM   #1
jaros44sr
jaros44sr's Avatar
Exhaust manifold
Thread size for this hole in the manifold. Believe it has to do with the AIR system I want to put a brass plug in it
image by [url=https://www.flickr.com/photos/97391199@N06
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 05-11-2025, 01:01 PM   #2
geezer#99
geezer#99's Avatar
Re: Exhaust manifold
Maybe here.
http://67-72chevytrucks.com/vboard/s...d.php?t=641828
Old 05-11-2025, 04:35 PM   #3
hemi43
hemi43's Avatar
If it's an oddball thread, run a pipe tap in it, I would use a steel plug, not brass.
hemi43 is offline   Reply With Quote
Old 05-11-2025, 08:30 PM   #4
jaros44sr
jaros44sr's Avatar
Why steel? I thought brass would be better for corrosion. I’ll search around my Kennedy boxes see if I can find a tap and wheel bearing grease
Thanks Geezer read the thread, how do you find the info……search?
SAFETY FIRST
AS usual, off topic
Jim
Old 05-14-2025, 11:11 AM   #5
hemi43
hemi43's Avatar
Brass is OK by itself, but when mated to dissimilar metal like cast iron it could cause issues especially with heat cycles. Will it work, I'm sure you would have no issues. I just like to keep different metals away from each other whenever possible. Good practice IMO.
Old 05-14-2025, 12:14 PM   #6
geezer#99
geezer#99's Avatar
I search with google images.
Old 05-15-2025, 10:16 AM   #7
jaros44sr
jaros44sr's Avatar
Good answer
SAFETY FIRST
AS usual, off topic
Jim
Old 05-21-2025, 10:05 PM   #8
Mike C
Mike C's Avatar
I don’t think that’s an air pump hole… There would be one in each set of cylinders. Looks more like a manifold that has had the generator mount cut off. Does it leak exhaust out of the hole? I’d try a 3/8-16 plug and see if that would work.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 05-23-2025, 01:27 PM   #9
jaros44sr
jaros44sr's Avatar
To answer your question it does leak exhaust….
SAFETY FIRST
AS usual, off topic
Jim
Old 05-23-2025, 03:05 PM   #10
hemi43
hemi43's Avatar
It's a port for the EGR or air pump. No such thing as a 3/8-16 plug, and that hole looks much larger than 3/8" diameter.
It will be an oddball thread so IMO the best fix it to run a pipe tap in it. I would start with a 3/8" NPT or maybe even a 1/2" NPT.
