Old 03-31-2020, 09:51 AM   #1
cebra
Brothers Shortbed Conversion for under $100
I am still unsure why people spend $450 for a Brothers Shortbed Conversion kit. I mostly duplicated the kit for about $75. The only missing items is the template to idiot proof where to cut. It isn't difficult 12" out of the flat under the cab and 8" off the back, there are even bumper bracket holes on the back that guide the 8". Here is the parts list to duplicate:
(Expensive Route)
Frame Stiffeners: Summit Racing CLP-6372RFS $40
Parking Brake Cable: Classic Parts 71-761 (varies by Trans) $14
Brake Line: Classic Parts 71-830 $45, I just did auto store lines and bent myself
Hardware: Tractor Supply Grade 8 Bolts, Nuts, Washers, Lockwashers (need 40x 1" or so 3/8" bolts) maybe $15
(Super Cheap Route)
Frame Stiffeners: Use 12" Piece removed split longways and welded back together
Parking Brake Cable: $10 Rock Auto (SWB Intermediate)
Brake Line: Auto Parts Store $10
Hardware: Same as above $15
Steps I Used (I didn't remove the bed, there are better instructions available on here but I am going to run through them generally as I did it as I think most people are paying the $450 for the kit mostly to get the template but it is really not necessary)
1. If pre-purchased stiffeners, mark a line down the middle, drill 2 bolt holes on top, 2 on bottom, and 4 in side...on each side of line
2. Remove bumper, measure 8" and cut (I used a grinder with a cut-off wheel
3. Remove fuel, brake lines, wiring under cab attached to frame rails and remove driveshaft
3. Mark 12" back from rivets on rear cab mount to frame
4. Measure ~8" forward of the line made in step 3 and draw line
5. Measure 12" forward of the line made in step 4 and draw line (both 4 and 5 need to be in a flat part of the frame)
6. Do "X" measurement to points in front of #4 and behind #5
7. Support cab, frame under cab in front of line in #5, and frame under bed behind line in step #4
8. Drill out/grind off rivets for cab support and remove
9. Make cuts on lines #4 and 5
10. Push rear frame forward to meet frame under cab
11. C-clamp in frame stiffeners
12. Measure same spots used in step #6 and align as needed
13. Drill holes through stiffeners through frame and bolt in
14. Remeasure X and tighten down
15. drill holes marked in #3 and bolt in cab supports
15. get driveshaft cut down, reinstall brake line, parking brake cable, wiring etc.
16. Weld in frame stiffeners and cut made
17. Reinstall back bumper
My Daily Driver Build: http://67-72chevytrucks.com/vboard/s...d.php?t=755668
cebra is offline   Reply With Quote
Old 03-31-2020, 09:57 AM   #2
cebra
Re: Brothers Shortbed Conversion for under $100
I know there were some issues with the Brothers kit (grade 5 hardware breaking and one cab support template off a 1/2") that may be resolved now but it is the reason I didn't go that route.
This takes about 4 hours to do, to me it really wasn't much more difficult or time consuming than replacing a heater core or window regulator on these trucks.
Old 03-31-2020, 10:48 AM   #3
rockyrivermark
I used the kit in 2017 and was absolutely baffled how they went through all the process of R and D and ended up 1/2" off for the cab mount holes.
If you take out 12" then that hole moves 12" not 11 1/2"!
seriously unbelievable.
Otherwise it was super easy but certainly over priced for what it is.
Mark
My build page
http://67-72chevytrucks.com/vboard/s...d.php?t=764662
My cabinet building site
http://www.cbcabinets.com
rockyrivermark is offline   Reply With Quote
Old 03-31-2020, 11:06 AM   #4
MDPotter
MDPotter's Avatar
Nice writeup cebra. I agree that it's not worth the money when essentially all you're doing is taking out 12" from under the cab and 8" off the back and replacing the brake cables and front to rear brake line.
Measure three times, cut once, and another way of being really precise is to cut short of the lines and then sneak up on them with the grinder.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632
1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047
1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184
1978 Chevy Scottsdale K20
1993 Chevy C1500 - 5.3/T56 swapped
2008 Silverado Duramax
MDPotter is offline   Reply With Quote
Old 03-31-2020, 04:54 PM   #5
CUDA8U
CUDA8U's Avatar
Looks real easy if you have any welding exp. at all.I wouldn't straight cut the frame for the 12" piece removed, it's better to cope the frame into each other, I would also put in a piece of flat bar on the inside of frame maybe 12"s long to box in the frame.
CUDA8U is offline   Reply With Quote
Old 03-31-2020, 06:11 PM   #6
cebra
I straight cut mine but did box it as you mentioned, I did not install the bolts as described because I felt comfortable just welding mine. The bolts add some support and allow you to drive the vehicle to get it welded if you do not have a welder. You can get as much on there as your are comfortable with really. I have seen straight cuts with no frame stiffener (full pen welds), frame stiffener welded in, frame stiffener bolted and welded, fully boxed in frame, full box + fish plate on outside of frame, etc.
Old 03-31-2020, 06:22 PM   #7
YBNORML
YBNORML's Avatar
I straight cut mine bolted it back to get her with a piece of c-channel about 24” long or so. Then had a buddy weld it all up for me. Easily stronger there than it was before.
I don’t have any pics of the shortening all welded up. So I added a few of the notch. Same guy. Excellent work.
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 03-31-2020, 10:01 PM   #8
KevinK7
KevinK7's Avatar
Originally Posted by YBNORML View Post
Then had a buddy weld it all up for me...
...Your buddy can weld
'68 C20 Utility 396 4sp (BuildThread: http://67-72chevytrucks.com/vboard/s...d.php?t=806904 )
'68 C10 50th
KevinK7 is offline   Reply With Quote
Old 01-22-2021, 02:02 AM   #9
nicklear36
nicklear36's Avatar
Could you show where you drilled the holes on the Summit frame stiffener? Thank you
nicklear36 is offline   Reply With Quote
Old 01-22-2021, 02:54 PM   #10
richards72chevy
richards72chevy's Avatar
I don't know how to post videos but some one on YouTube just moved his rear end forward then wacked off the back half of his frame.No welding.He said it worked out!
richards72chevy is offline   Reply With Quote
Old 01-30-2021, 10:21 AM   #11
richards72chevy
DD Speed shop on youtube did the no weld short bed conversion if any one is interested in looking it up.
Old 01-31-2021, 06:16 AM   #12
53burb
53burb's Avatar
I was curious as to how they did it.....it's a Chevy, but with leaf springs....
https://www.youtube.com/watch?v=rqguJcnbHyg
53burb is online now   Reply With Quote
Old 01-31-2021, 09:25 AM   #13
tutone
tutone's Avatar
I've done this the straight cut route as well as the Stacey david way. It certainly is easier when the cab is still on to straight cut it. That being said, I feel better about the offset cuts with the cab off. (See my build thread). I use a long gusset welded in solid that spans the weld and ties it all in on the back cab mount. I don't expect much flex in that area, but mine is a 4wd and any offroading might create some. Cutting any factory engineered frame is an undertaking that should be done carefully and with a lot of thought.
:My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=807535
1969 C10 swb/1968 Camaro 350/4spd
1955 210 2 dr sedan/1998 RCSB Z71/1977 Jeep CJ5
tutone is offline   Reply With Quote
Old 01-31-2021, 03:54 PM   #14
hjewell2
hjewell2's Avatar
subd
hjewell2 is offline   Reply With Quote
Old 02-22-2021, 02:04 PM   #15
Big Kev-O
Big Kev-O's Avatar
If I understand correct this method would not require the cab to be removed, as stated in the brothers instructions. Also I assume the reason you drilled out the cab mounts was to bolt in the C-channel as the brother kit does.
Does this drawing represent your measurements and cuts?
Thanks for the right up, I really didn't want to pay the $ for the brothers kit and was about to get a c-channel from a fab shop. Your solution seams ideal.
Made in America by Americans
Big Kev-O is offline   Reply With Quote
Old 03-21-2024, 11:16 AM   #16
Basketcase889
Basketcase889's Avatar
Just wanted to bump this thread for confirmation to the picture above?
1970 - Green LWB C10 - 250 I6/3OTT
1969 - Blue/White LWB C10 CST - 350/TH400
1950 - Original Patina 3600/S10
Basketcase889 is offline   Reply With Quote
Old 03-21-2024, 11:38 AM   #17
tutone
tutone's Avatar
You can easily cut 12 inches out of the frame in between the 2 cab mounts. I think the kit uses a locator hole. The OP said he didnt remove the bed? The bed will need to be removed in order to cut the front bed mount off. As far as the drawing, it will probably work. I dont have a framerail in front of me right now. But 12" of straight frame is 12" no matter where. Another couple of things to consider. The cab needs to be lfted enough in the rear to slide the frame brace under the back pinch weld area of the cab bottom. Secondly, and very important, the "stffeners" also act as guides when sliding the frame back together. Take your time. It is some good instruction.
:My build thread
Old 03-21-2024, 03:58 PM   #18
Shifty One
Shifty One's Avatar
Indeed!
1987 V20 farm-hand rescue
1998 C2500 lot-rot rescue
Old 03-21-2024, 05:00 PM   #19
Accelo
Accelo's Avatar
"I used the kit in 2017 and was absolutely baffled how they went through all the process of R and D and ended up 1/2" off for the cab mount holes."
Their wasn't any R&D. LOL.
Accelo is offline   Reply With Quote
Old 06-12-2025, 01:27 PM   #20
Basketcase889
Just going to bump this one more time, since I am going to be attempting this on the weekend.
Any tips on what holes to measure off? Or just pick a spot and make sure its the same on both side... like people have said, 12" is 12"
Old 06-12-2025, 03:28 PM   #21
rockyrivermark
So you aren’t using the kit I assume?
I can check my truck today and take some photos.
Yes. Remove 12”. I believe the kit removed 11 1/2” which makes it difficult to get the body bolts lined up.
That was 2017 for me so going off memory
My build page
Old 06-13-2025, 09:23 AM   #22
Basketcase889
ya no kit. Bought the frame stiffeners off Summit. They arrive Monday.
Super straight forward, but wanted to ask again incase there was any new info, or people confirmed a landmark to start your measurements off to take away the guess work.
Thanks!
Old 06-13-2025, 09:50 AM   #23
LockDoc
The Older Generation
LockDoc's Avatar
I posted this thread on the Longshot Fabrications frame kit back in '24.
https://www.67-72chevytrucks.com/vbo...d.php?t=855792
Leon
