Re: need help picking tire size
Speedway sells a fully adjustable test fitting jig for checking tire clearance. You could make up something like that out of sheet metal or 1/8" plywood to test for the tires you want to use. With jacking of the suspension at various points, you should be able to get a good idea of what will fit.
https://www.youtube.com/watch?v=m4nGR6kWeUI
'67 GMC 2500, 292, 4spd, AC |
| Bookmarks |
