#26 |
Re: To electric fan? or not?
I tried electric fans several times, from camero/fireburd LT1s to purpose built radiator/shroud/fan for my truck. All had problems from heat build up and various speeds to relay/controller failures. My 72 with a 383 & 350THM with a high stall converter, mid 90's 1500 serpentine system, stock style radiator, and stock shroud (with a small carve out to expose the fan blades properly), with Vintage Air running most of the time, temps in summer exceed 100 for several months, Derale trans cooler, mostly in town driving with some freeway. Stays mainly in the mid to high 180s, creeps to mid 190s in the summer months. Serpentine system all stock except for fan which is Derale 18 inch fan part number 1791. 12 years and about 30K mies with no issues. Good luck, Lee.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have all original numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
#27 | |
#28 | |
See post 8 of below: https://www.bimmerforums.com/forum/s...iring-question This shows it set up with a relay so fans do not run with ignition off. If you wanted to always run fans with A/C on then add a relay to ground the high speed fan (#2 on Volvo relay) with a/c on. If you wanted to turn fans on for high trans temp, add an open/closed temperature switch like a dash lamp switch to ground the #2 if it went over a set value of whatever switch you buy. This can also be used with dual single speed fans by using 1 of the outputs for each fan. On low you get power to #1 and with high you get power to #1 and #2 outputs.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project Last edited by MARKDTN; 06-12-2025 at 04:49 PM. |
#29 | |
#30 |
The photo is of 2000 Contour/Cougar dual 2-speed fans on a '69 Mustang radiator. C10 radiator cores are about the same height but are about 4" wider so if you used that you would need to make your mounting system cover that 2" on each side. I like using OEM fans because the motors are available at any auto parts store if one goes out. This one went across the country with no issues and used the BMW switch/Volvo relay. After the photo I squared it up better and sealed that small open area at the bottom.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
#31 |
![]() Join Date: Feb 2022
On tranny cooler location. I placed the cooler flat offset away from cab floor. Exhaust allowed and was out of the way. Use a puller to get air moving across the plates with a tstat helps get up to temp before fan trips on. Not the most efficient but keeps heat out of ac condensor and radiator. Assuming electric system is up to the task of 3 fans.
#32 | |
![]() Join Date: Jul 2011
#33 |
Clutch fan. Simple and cheap. Done.
Electric fans. Loop back and ask the internet with no troubleshooting, what's wrong or why don't my fans cool. Hmm... Last edited by franken; 06-14-2025 at 02:16 AM. |
#34 |
![]() Join Date: Dec 1999
Installed an 800w 19" fan in my truck. Used by the OEM's in newer vehicles. It is a PWM fan and will be controlled by the Camaro ecm. Yet to see how it works, but I do not expect any problems. See people running dual fans and setting different turn on points. This just recycles under hood hot air from the unpowered fan and reduces flow through the rad. Also not sealing the shroud or even blocking off a large portion of the rad with a flat plate? There are several factors that need to be considered.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 Last edited by Richard; 06-14-2025 at 03:55 AM. |
#35 |
>>The C4 Corvette fans for example come in single (84-89) and dual (90-96) styles.<<
The "single (84-89)" was standard, but there was an optional "Auxiliary" pusher fan on the front of the radiator. I believe it was available as an option, but was standard on the vehicles with the Z51 suspension option.
'67 GMC 2500, 292, 4spd, AC |
#36 |
Just got the truck back from the shop Friday, drove it home and 8-10 mins at EVERY FRIGGIN red light on the way *facepalm* never overheated but it was starting to creep up the longer I sat at the lights. I'm going to eliminate the spacer tomorrow (if I can figure out how to not die of heat stroke) and see if proper placement helps... I like cheap and I already have the mechanical/non-clutch fan (not really a point in a clutch here, too dang hot 10 months out of the year AND I doubt I have room) Need to see how it works out.
#37 | |
#38 | |
Ram-A-Lam-A-Ding-Dong
![]() Join Date: Jan 2013
#39 | |
#40 |
Honestly I have maybe an 1-1.5" between the shroud and the pullies, I was going to try to eliminate the spacer because the fan is inside the shroud and from what I've learned here it needs to peek out the back(engine side) of the shroud about 3/4 of an inch. I will try to get some pictures tomorrow 👍
#41 |
Noise is the least of my worries, can't hear half the time anyway *laughs* but I don't disagree with you if I had room I probably would, but I doubt I do the serpentine system moved every thing towards the Radiator anywhere from 4 to 6 inches and I'm thinking a combo of trimming the shroud and losing the spacer (it is only 3/4") will give me the proper clearance/set-back for the fan to peek out of the shroud, but I also have to worry about how close the fan gets to the pullies and belt too.
#42 | |
100% agree with the sound part being the least of any worries when you're chasing overheating Gremlins. Personally can't stand the noise electric fans make but they do work well in certain applications. I forgot you had serpentine system pushing everything out that far towards the radiator. If you can't remove the spacer, trimming the shroud may be in order. We'll take a look at the pics when you get some. Good fortune. |
#43 |
I did the dual Stall fans. Set up with two speeds, making it easier with two computer-generated turn-on points (LS). Both come on full speed whenever the air is on. Both fans on slow speed at 165 deg and both on high speed at 180 deg. The system has been foolproof so far.
#44 | |
So...mechanical fans/clutch fans are NOT always the go-to answer.
"If it ain't broken, fix it 'till it is!" |
#45 |
My k10 is a 6.0LS and I used ford Windstar fans on my stock radiator. They were very budget friendly at the local wrecking yard. Controlled by the ECM.
The fans don't come on unless i am going thru a drive thru.
1962 C10 Longbox LS 5.3 4L60E----Sold$$ 1972 K10 Custom Deluxe LS 6.0 1950 GMC 3100 S10 & LS swapped---sold 1955 f100 LS swapped----sold 1968 C10 shorty project 1971 C10 longy project |
| Bookmarks |
