![]() Join Date: Jul 2012
88-94 steering wheel on 68 with working horn
I apologize if this has been covered before, but I cant seem to find the right answer. I really like the 88-94 chevy truck steering wheels, but I cant come up with the correct combination of parts to make the horn work.
Currently i have the 88-94 wheel, using the 68 plastic spacer/bearing race under the wheel but do not have the horn hooked up. Using the plastic spacer from the 88-94 doesnt seem to have the correct bearing race and will bind. Has anyone successfully this? Am I overlooking somrhing simple? Thanks in advance!
"Rusty" 1972 K20 Cheyenne Super, 496, A/C, Tilt, Tach, Buckets, 4l80e/NP205, 4" Rancho Lift, 35" BFG AT "Ramp Truck" 1972 C30 Ramp Truck 350, Air Bags, Factory A/C. "1968" C10 Shortbed project |
![]() Join Date: Dec 2014
Re: 88-94 steering wheel on 68 with working horn
subbed
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 Last edited by dagnabbitt; 06-20-2025 at 12:53 AM. |
I have a 1972 with that wheel and the horn has worked since I puzzled with it for a bit. I doubt the year makes a difference. You need the (usually green or white) round plastic spinny bit about the diameter of the steering wheel base and the part with the wire in the column.
This provides a ground to the horn relay when the button is pressed. Start by checking for power to the horn relay. Both sides of the relay will have voltage since one side is waiting for a ground from the horn button. I did some searching and could be wrong since I haven't looked at mine since it was fixed. This link has a pic of the parts it says work. These are the same for many years. [data:image/jpeg;base64,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 ghRlTXMXnN2UQktQOCa4aoOaKC2i8W6IraqBsVApwSiNU56AhVUW0SnN1TTogJUUuyAhE46oMyGukspsispstuYLL1kdlFkA2TSP IvMCY4LUKrEIbJjghsoBspd6QpsvPGgUUshAUwhQAggBOZHlHdDCPMn3AGqYEPZ03Syxw3TnyMGuZVpKlg1vZYEOCGwB1SJKyP6/wCqETmQ2Y0E+7rIGvc3khuSNAiax/qPDB9tVJzW3/CYFFj3aBo+6gxD53gdiidfmlndVUmOEbhx7nRIexhOjbDumFCQi4UWBuoF1Fv5UZQlQdGFKmymy2wGy9ZTZTlQeYEyy80KVuIS9q AhNkNt1XfKwc1mqIBTINAqj6xrdASeyDjTyfpsP3U0WSRzS3SsbpdK+GqJNXyBo52RNoox6y5xUUD6sDQEqnW4kadt5btHuVdrHR 0VFJMIxdo8t+vJfK8axeeuqHtLiW319z1WbcWR0uJeKWQuyskzk8mrLk8Tzu9EQPc3XNgjd24Tozf0g/YXWe1b9P4jrGf8tTuJ3zMuFsweLJCT8RhWHyG4s7hEH+65aGnqCwScCTJ9WXRWWtma2/w8pHs1RXXweJcKkfafDZqcHd1POSB/4latNNRYhduFYiHSgfoVQDHEex5rgmuAsJWlhOweLFMay502TaO1kLopeDURvhlHyvH+a8VmYdjrxTtocUHxdHazJHfqQdjzHsrU TjG5jHOEkUgJjlHP2K1LqYcQhKI3+ygqgCgKMhARqg6ey9ZKkqY2fMqz68fI0u7C63rC8gMgG5VH/fJfSzL3KJtA+T9eUnsinSVzW7EJDq2V/wClGXdgrUVFBHsy/fVWRGG7Wb2CvadMwQVk2r3Bo6FE3DhvK8uPQLRsBuvWumGqrKaJnpYO5TQzRNyqLJhpTmoLdU5wQWQZPiSJ0mDT5DbKQ77BfHJw5 tQ5h01J1X2vG2OdhswZ6raL55ieGx1j+LFZspHnbb1Lny9tRUpPC1W+mbUVAbEDqGyHUjsijp2wuIaAS31ZNdFuTF4ggLsRjqXyM uYgwtcwDqVnTSzS1ZhoIWvntZzraD/V1LnwdruDU8csjIa6d0dGHcQNLj5tNvZbcOE4YJS2Goqm3sA1s4I99wFiwYFikrQZ8SMI+mFoAV2HCcUp2/wsVfI0bsnja9p76J4rrc/w/JkvSVzJw7y8Kojtf2vtdYtVg8bKh8T2upJ2mxy6tHcfsjZPW0f8OpjNMXaCeBxMTj/M35e40VFkWL1Va+OjmjhY2wBe3M5x/ZTDUVFJLSuDKloF/RI30u+/X2U0MkgjkiDvQ4Ob7LSd8dCz4TF2QzU8gtxGjIWnrbmsallijrRSh2d58xN/lHVT017dRe4F+ihJbJmOmyYHLUR4obIlCqNqPD4W+vM7urLImx+hrfwnli8AtsF5VOVHYKvXVkGHxCSeQ3d6GN1c7sqLDWdEqoqa ek0qJmMP0k6/jdc9WYxWz3yH4aIj0xm7z3PL7LMwvD6nE698bZOFTR24jhq5x7qjpZMdpB+k2ST3DbBJOPNOog093Iz4WwssvLG5xbqZHyG497rG dGxrpRAc8d7MLuisStU48wGxgufpDxcom4/SN/VZNDz1bmA+4XLVcFXDNxLBw3027KtaoxADjF8FKDpbyvnI6c2tvzO6l6WPoTJGyxCSM3Y7XMpXECoqWSsqIJ3MMYs0AmwHSy6LBs YZWjhS+SYchs7ss9qu1zS+mlaObSvntaDHPbcL6U9twQRuuH8RUboZSXN8pN8wC5/0mxrjWWJTlLmFjjtleOXdPw6rlo5bQ0zTxZGlzgb6OICoHy7aoY5cs8Zc45Q4Xt3XOcsbx9BEVj+Neqr4jiFJh5j+Kfw+JfL72t+ 6x6LHHkPZmlGU6ZoswVDxJirqiOOMGF7bXNmG41PXbsumsY26jxBhHCcJKgFpFiCFzdZj9FA/NBJe22UarnHuyZhkab8yqsjRfNp2spqtPEfEdXWktYS1v8xR+HSRO+Z7i550JKxTbkNVvYHCWxg2OvsmDsaZ+Zo7K0DoqVILNGnJ XWDRWVBgqVAClaHYFqDL7J1l4NW2GfitdHh9PncWukdpHGTbMf2C5B9RJJUmWV3Flf6pOnsB09lqYziElWamnLGGJriG+Uh+m9nX 6rmIYqVu8dcQP+vkNvs4FTcq40Hyeb2KGjlqWVIZRGZ1Q43DITrbqdrD3JVapp4naw8bKB6pXhzvyANF23hzDWUGHtJaDUSgPmdu SbaAdAFrWcVI8HxGraDiuIuA34ULs3/sRa/2+5T24BSNBGeYg73drb8LYyqLX27Irn6vw+2SN4ppNOQkAH9Rb+yypYmwQi4bmi01Hpsu0t+VyWIOOIeJJKGnlyA24jxqRlbr99L fjooMlnnzPkNmk6C1kmRzqSobJFpfUFdbF4XwaHV9FHNIdOJO0PefuVlY9hOH4fGwUrBC55/RabC3XLyTTG9QVPxVLHLbVwSq6lZUsIkYDoqfhXM7B4nPO97drrWcFmq4HE/Ds8Li+hfdt7mKQG32WC9lVHNw6qkewX9TRmH+S+pywg6qnNRxvvdoPcLnZGtcEcKriM8LWuHVr1QrI56fSpvGeryvpLMH4voZlH1 X0CRUeFcMkOatmzH6WKZF18plnjvrI13a5Sw2Wf0Rut9R0C+q/wCHfDTBZrJg7a5v+y3cAwTAnVxpqsthe1oMDXDK199yOpHTsnSWvj9Hg743tNSHB7hdocLXHsuooKPIwDJb7LqfFHhxuCxVHDxOo qqeZhaWSyZjCTzA2F+tgOixPD+aow9pl9bTlJA9XQq1OK1DHZoCsBlgrEdP1C85ltFY1Vey9ZMLUNlpHZWUgaIrL2VbYfPTE9nFb I8GRszw7a48xt/RJyiO4dfzHoujx6gEczp4WH+LYkAc1zseFyYrilPSuc5lMQXTFmheB8t/dUVzWwmThRlrnbENNyurwTH6R1NFT1UjYZW+UOfcNP36rcw+ipsOhZBRwxQxgbMZa/43WD4sfTSMZGxrH1Afd7mgeUdCU1PToWFsrc0TmvbyLTcKtVVtJTMHxFVFFrs94B+w3K4T4djh5omEdhcKlV05yjgFkLdbkC9vey WGuoxTxKxzHw4e0gG4MxFj75Qf7nbkFxfFm+NMsDnNnzXzNJuPe63MXwZ1FDTGGqM0Ew/VIA15bdRdVoKWOnbmGvUlZs1qXF9mLYkIW8SvkOmlmM/vYFYFc6StrY6anc99TOdXE3yt5lKrcTknmNFh8ZmqCctm6/c9F13hHw3/ALNj+Jq/PVy6uceXsEvfon628PpG0tFFAwaRtATiNU6Rl22BIH8u6EtbYADbnbVQJLQSoZC0gufoAmOYTsjqRZjGt2tcnqs0VJZXONmDK3kF XeL+rVWHAJTgkiqEzBfZDXSQ1FOIquESNA3teysytNjYLGxWaogY4xEbdLrHOaMetpMKLxHaqlAPlidM4tv2JXV4ayOCBsWVuUfS 21lxVLXSSSh1TE3MD8rC0fgkro6KrcRe+6zxn2vToeC31QkuHRV5G6qIKgtAylOmAc3iM2PqtyK16VUc1LLdU8pZ3W4jsV5HZQAu msFTwMnYWOHlP5C5bEcOqqCbitY6WP6ovU37BddZecATawPfZFfPpcWkkdwxiEpfa2Rzi0gdtCqxljyXfKBcruq/BqGvFqumik7tBWPP4IwyQAs4sXQMlcAP6rOjnM7QCWG4GuiXKYzHxZSGs5lzwFvDwFQB/wDxFVb/ALzv3ToPAeDMlEklMJHfXIcxWvK/SeLOwCpp8awapw+GbiiEXik3Den3WRJ4bxvFKrhyuFHTA28huXjrdfRKDCqShaW0sTWDsrJZY6AKZTHP4B4ZosHhAijBk3c9w1JW 0W6AAAAJ2VDZMwJIS3DTa6suCU4WUVn4jgOIT4c6v4T6kvH8CmjIDRf5nXOo73XJ4rLXU1EZ3U0NDWwvtw6d5s/TzXB0t2X0Cmx+rw2EN+HFTCNhezmrlvGVXP4lqYjFQvpmxNsZC69x2XPyhhuEV4xGjZLYBxaC4dO34/oruT2WdgEDYKWzBdptkPsAtXkrO1KMaoVtLnvdoIWndLkFwmDm34YzMfJ/RHFR8M6aBbfBBN0MkIA10UVRZmYL9FfoTxWPj+6pOlhBI4jNdN1epQIaeSU6dEorHc90JRc79UKo7UKbIrLxC6sBNlFkYaoIQCRq FFkRUgaIAyrwCOy9ZAGVeyoyEPNAstQWTiLoS3VAkjVLeNdFYLUBasqwcUe+FuaI97rApPEYFaWPkjkZ6XD6V0+KwZ4iCFxM2EiO RzmMyk6rjy4d6sdYKcRMD6YAxDYDl/8AEyN+ZuqyMGq5qUCN13x/SeW63WfDzC40J3Wp0F31UFONO75LEKPh39AroRtqihw+TFJo6SOQRl4JuegR8B3zENHVTm4Ya6mmLZGOzNePlKloxPE+BYnhNa+G hpA+kc3NxXR5/wAe6wziT6LGfhIX3pahoPCOzHW5Dl2X0k+NJaWEtrKB00gGroXCzvsdl8vfTmtxt9SGCIZi8Mvci5U8pUdPGbtHPS68hiAaxrWnQ BGtSq7oL1lNivLqyEBeKJTlPRABHResS0XGvsmWXgEA2XrJltFDgLBQLICAB1rENGuwTSFFkCygI1TSENkUshAQU4hLO6CpUxB4W TUUbXO1at14ukSQgg9Vz5RY59tGGO0CsxtyiyuPis5LcyyRQB5aNCVHFdzK8W+yEq9IF7nG+pVCoqHQ3NiR0Wha+6z66O7SAN1my DCrMXifI5kczmuGhHugoTYukzXc86lLnw0GYvtuVYp4CzRScZBpwvu1OzJETbNTQtj6EvEIrKSAV0QAClS1tl6yI9ZesvWRAIBC8 QiIUKKCy9lR2QoAIQEJpQWQAQlkJxCBwQIcEpxsU94SHDVSgHAO5JL4086JZ3WVV3Rpbo1ZO6W9AjIFXmiDr3VpyU5Bly04vtdL4 A6WWg9uqU5iiq4ZbReyppFkNlYO/CIBQ3VGujIV6yKy8EEZVNlKmygWQvWUvzD0usF6+UdboIKEhEVCACFFlIcHatNx7LyBZQlG610JCBLwlOAT3hJcCoEuSjunOCBwC KS7dLcmuSnoFOS3WTCdUpygU5JdunOSnIFOQFG5ATqg/9k= |
The link in the last post is fubar. Here's another.
I'm pretty sure the springy round disk at the bottom right faces down like an upside down bowl. https://www.67-72chevytrucks.com/vbo...d.php?t=809375 |
All my wiring and parts work, im completely rebuilding snd re wiring this truck. I just needed to find the right cancel cam that works with the 68 but accepts the little twist lock wire from the 88-94. Seems like my best bet is going to be to modify the 68 cancel cam to have the little twist lock grooves. I don't think that would be too hard with a little patience.
If a 69 and up cancel cam fits, might work, found this post.
https://67-72chevytrucks.com/vboard/...43&postcount=2
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
![]() ![]() Join Date: Jul 2002
You don't need much, Just the slip ring/turn signal canceling cam for your particular column. I get the horn wire for the 88-94 wheel. Put in canceling cam, then add the wheel. You mahy have to trim a little nub off horn wire, but push it in. It should be a snug fit and the spring should keep the pressure to bottom of the canceling cam. Plug other end of horn wire to horn butt and you should work fine.
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 06-20-2025 at 07:48 AM. |
| Bookmarks |
