Re: Hey you all, how the heck you doing? I'm working on my truck again!!!
I also use plywood strips cut to fit the longboard paper. I staple the paper onto the plywood. they work great for getting straight panels. i found the plastic longboard that a lot of guys use, with the handles on top and a thin foam under the paper work surface, was allowing too much flex and panels didn't come out as flat as expected. long rigid sanding block, light pressure, even on filler, shows and sands the high spots.
yeah, preaching to the choir, lol.
