Old 06-25-2025, 02:52 PM   #1
dwjet2
Need help identifying these
I am doing a frame off resto of my 72 C20. I had the frame sand blasted and then I painted it. Once I lifted the cab to put it back on the frame I found these under the cab and have no idea where they go or if they even go to it.
Any ideas guys?
thanks
dwjet2 is offline   Reply With Quote
Old 06-25-2025, 05:38 PM   #2
PbFut
Re: Need help identifying these
Exhaust Hangers ??
PbFut is offline   Reply With Quote
Old 06-25-2025, 05:51 PM   #3
Orefactory4x4 swb
Originally Posted by PbFut View Post
Exhaust Hangers ??
That would be my first guess too.
Or some kind of step hardware.
Didn’t see them on my build, curious though.
Orefactory4x4 swb is offline   Reply With Quote
Old 06-25-2025, 07:35 PM   #4
jaros44sr
jaros44sr's Avatar
Under side of body for seat reinforcements………….thinking
Depends on dimensions?
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is online now   Reply With Quote
Old 06-25-2025, 07:46 PM   #5
dwjet2
I will look at the possibility of them being exhaust hangers. Truck never had any steps on so that is out. I replaced the bench seat years ago for buckets out of a 2000ish Silverado so I don't think it is that. I have looked though the service manual and all over LMC's website and cant figure it out. Maybe they do not even go to my truck, it has taken 5 years from tear down to get to this point
Old 06-26-2025, 10:50 AM   #6
kwmech
Frame reinforcement inside the frame channel for the big block mounts, right and left side. For sale ??
Old 07-03-2025, 06:22 PM   #7
Classic Bowties
Always on the hunt...
Originally Posted by dwjet2 View Post
I am doing a frame off resto of my 72 C20. I had the frame sand blasted and then I painted it. Once I lifted the cab to put it back on the frame I found these under the cab and have no idea where they go or if they even go to it. Any ideas guys?
^ ^ ^ dwjet2, we missed this one when you originally posted but here are a few of our old saved folder pics to go with kwmech's above post, your brackets in question are the OE front frame to x-member doubler braces that were used/found on the 2wd 72 C/20-30 trucks. The first pic shows where and how they were mounted to the inner sides of the forward frame rails, there is one LH/RH specific inner brace and one lower flat plate per reinforcement setup, we do have a few of these 4 pc. OE frame brace setups pulled/ready to ship if anyone needs a set. Mel
***For any return/past customers & friends***
Before sending of any funds, please wait for a confirmed total and instructions for
sending as our payment account info has been changed as of Jan. 2023. Thanks...
Classic Bowties is offline   Reply With Quote
Old 07-03-2025, 08:44 PM   #8
RichardJ
These were on a '76 C30 with big block. I was originally going to use the '76 crossmember on my '67, but ended up putting the '67 back in because the forged ears on the crossmember looked stronger. I thought why not use these as well and only had to redrill the top hole.
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 07-03-2025, 09:24 PM   #9
dwjet2
Awesome guys thank you I can move forward with those now
Old 07-07-2025, 01:45 PM   #10
70STOVEBOLT
70STOVEBOLT's Avatar
Are these really necessary? I see Mel posted the application being C/K20 & 30. What about the C/K10?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
