Looking for a new power steering box to replace my worn and leaking one on my '72 C/10. Would like to upgrade to a quick ratio version, and have been looking at the Borgeson as well as 2 from LMC (though not sure of the difference in the 2 they have).
Any opinions, pros/cons, etc. would be appreciated. Thanks. |
![]() Join Date: Nov 2013
Re: New Quick Ratio Steering Box
Borgeson quick ratio on my '67 works perfectly with the coil over suspension
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer .............
![]() ![]() Join Date: Jan 2005
I installed a Borgeson on my '68. It works well, but it required significant clearancing with a grinder on the mounting surface side of the gearbox to clear the bulges in the frame. See posts 21 & 22 in the following thread
https://67-72chevytrucks.com/vboard/...d.php?t=827577 |
oof that's alot of grinding on a new part.
I'm on the RedHead bandwagon...
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
I've had a Borgeson Box on my 72 for a couple years now. Bolted on with no issues and love it. I also replaced all my front end components, and I mean all, so truck steers like a modern vehicle now. Redhead boxes are good but are rebuilt by them. If u buy a box from Redhead and they have a core charge and u have to send your old one back to them after u get the new one and if good for them u get the core charge back. A Borgeson is a brand new unit so no messing around with cores.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " In the end, we only regret the chances we didnt take " " Time is the only currency we spend without knowing the balance, use it wisely ." .. |
Anybody happen to know what size the bolts are? Like to have spares in case I break one off.
I also added a Borgeson Box on my 72, put it on last year. Bolted on with no issues and it feels great. I had to get it after ruining my original one while trying to rebuild it ☹️
WHYBYNU when old will do
I will pick my truck up Monday from the shop, installed Borgeson quick ratio box, pitman arm, upper and lower tie rods, idler arm, and steering pump. Replaced all the ball joints when I did the Wilwood brakes last year. Read lots of good reviews on Borgeson boxes.
71 Cheyenne super 2 tone green and white ZZ6 - Th350 4/6 drop 20x8.5 / 20x10 Billet Specialties |
#12 | |
#13 | |
Well that's kinda the general plan for myself. Replace tie rods, pitman, idler, ball joints, and steering box.
#15 |
Quick update picked my truck up after installing a Borgeson quick ratio box, rag joint,tie rods,idler arm and pitman arm all i can say is holy smoke what a difference! Had about a 20 mile trip home unbelievable how much difference it made. Absolutely no play in the steering, I'd compare it to a new car/truck feel. Have to say worth ever penny spent.
#16 | |
| Bookmarks |
