#26 |
![]() Join Date: May 2006
Re: Dash lights
Temperature gauge easy fix it’s either sending unit or wire, gauges are pretty bomb proof easy access
Fuel gauge probably needs to be dropped there is access to the ground and wire Amp gauge you’re on your on, I’ve studied that for years still don’t understand how it works, got lost when it talked about a shunt wire
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 06-26-2025 at 07:33 AM. |
#27 | |
![]() Join Date: Jun 2022
Re: Dash lights
When I was a kid, I plugged my shiny new Radio Shack Multimeter(set to Amps) into an AC socket, and learned in about 1/60 of a second that direct measurement has it’s problems
1970 C10 Custom longbed 350/350 “Carburetors are forgiving, timing is not” — Thunderhead289 |
| Bookmarks |
