Old 07-08-2025, 01:35 PM   #1
Bandit130
Bandit130's Avatar
Quadrajet Replacement
Planning to replace the Carter Q-jet soon. Wanting to replace with new. Have not purchased new before, only had rebuild. Is there anything special needed to be done prior to install?
TIA
1974 Cheyenne 10 LWB Stock 350 W/HEI /TH350/AC/4 BBL Quadrajet
Mopar by Birth
Chevy by Choice
Bandit130 is online now   Reply With Quote
Old 07-08-2025, 06:20 PM   #2
cadillac_al
Re: Quadrajet Replacement
Just save your old one because there is a good chance you will want to go back to it. All my old trucks still have the original carbs. I have a 74, two 76's, and a 77. They don't really wear out as far as I can tell. The throttle shafts may get a little loose but that minor vacuum leak doesn't seem to affect the way they run in my experience. I always change the throttle return spring to pull from the front to slow the throttle shaft wear.
As far as new, you are looking at an Edelbrock or Holly or a rebuilt Qjet which isn't really a new carb.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 07-09-2025, 03:54 AM   #3
Ziegelsteinfaust
Get it rebuilt by a true professional. Such as Quadrajet power. Just to name one I get my parts from.
Ziegelsteinfaust is offline   Reply With Quote
Old 07-09-2025, 11:45 AM   #4
Bandit130
Bandit130's Avatar
Had 2 rebuilds in 10 years. Last rebuild was in March by the same shop. This shop only works on carbs and throttle bodies. Been having fluctuating idle RPM and periodic dies possibly flooding on it's own.
The shop may not be rebuilding good enough not really sure.
Mopar by Birth
Chevy by Choice
Old 07-09-2025, 12:02 PM   #5
geezer#99
geezer#99's Avatar
Why do people always blame the carb?
Have you checked the distributor?
Could be weights and springs problem.
Have you checked initial timing?
Old 07-09-2025, 12:47 PM   #6
Bandit130
Bandit130's Avatar
Yes. distributor checked out thoroughly. When it dies at stop sign or light, take of breather and can see gas on carb. After sitting for a few minutes, will start up and will be ok till the next time. Not a consistent occurrence.
Timing checked and adjusted as needed.
Mopar by Birth
Chevy by Choice
Old 07-09-2025, 01:33 PM   #7
Loco83
Loco83's Avatar
I have 2 Rochester Qjets that have worked non stop for me, plan on keeping them forever.
Loco83 is online now   Reply With Quote
Old 07-09-2025, 01:37 PM   #8
Dead Parrot
Could be something as simple as the fuel filter going bad. Just takes a bit of rust or dying gas line or fuel filter bits to temporarily cause the needle/seat to let in too much gas.
It will be difficult to get a perfect match for your OEM carb even you buy a newly built Q-Jet. Likely your choice will be a generic tune for a stock 350 with options to buy jets and rods to tune to your application.
Dead Parrot is offline   Reply With Quote
Old 07-09-2025, 07:12 PM   #9
truckin 79
A quadrajet is easy enough to take off intake manifold and then remove top airhorn. I bet you just have some crap in fuel bowl or by the jets. Be carful with top airhorn gasket as it is easy to rip because primary metering rod hanger is in the way. There are plenty of videos online to guide you through this. Not a bad idea just to buy a rebuild kit just in case you do rip the top airhorn gasket. Also the float valve could be worn as well. I have gotten so good at takening off top airhorn I just do it on truck............I do not recommend.........only for the angry and pigheaded.
79 Chevy 2wd BIG10 350 TH400
truckin 79 is offline   Reply With Quote
Old 07-09-2025, 07:56 PM   #10
ron350
ron350's Avatar
It is sad that so many people don't want to rebuild a Q-Jet because of the horror stories generated by people who did not purchase a Q-jet book.
I think the secondary metering rods and hanger messes them up.
Stock 75 C10 step side.
350 2 BBL, 350 trans. 150K miles.
ron350 is offline   Reply With Quote
