Brake Booster Version?
Now that I have installed a dual chamber master cylinder I would like to upgrade to power brakes. From what I have read for 64-66 the master cylinder was the same regardless of manual or power so I should just be able to add a booster.
However when I look at the booster for those years there are 2 versions (Horizontal Bracket & Vertical Bracket). Is there a reason for 2 different versions? Can I install either of them? |
Re: Brake Booster Version?
The only differences I see:
1. 37 comes with a bracket while 35 just comes with the studs to install another bracket - stock or one like Captain Fabs here on the site. 2. 35 comes with a brake pedal rod extension and 37 does not. 3. 35 is "cast iron" and 37 is listed as "steel". 4. Finally, 35 is listed as "remanufactured" and 37 is listed as "new". That all said, you can dial in your setup a bit with booster selection. I went with a dual diaphragm booster that was slightly larger from 2000 something S10 based on my master cylinder bore, pedal swing, and drum/disc setup. I used the 60-63 bracket Captainfab sells to get me a hole for a clutch master cylinder as I am switching to a hydraulic setup versus the mechanical linkages that are stock.
Travis' Tribute Truck - 65 C10 Frame Up Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=495073 |
What diameter master cylinder did you buy?
Manual brakes generally use a 1" bore. Power brakes generally use a 1.125" bore. The pushrod pivot point on the pedal arm also needs to be in the correct location for power vs manual. The stock 64-66 pedal ratio for manual brakes is 6.25:1, power brake ratio needs to be around 4:1 so you'll need to move the pivot point by drilling a new hole farther down on the pedal arm. If you already have a 1" master cylinder and the pivot point is still in the original manual brake location a booster isn't needed, it'll stop great without it. That's how my '66 is set up, stops great even when towing.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
#4 | |
I believe the 4 wheel drum masters were all 1.0" bore for manual and power even into the second gen dual masters.
#5 | ||
I posted the math on booster assist, pedal ratio, and master cylinder bore size in another thread, I'll copy/paste it here. It's fine to make the brakes more powerful, but you also need to do it in a balanced way so they're still able to be applied in a controlled manner. Without abs you don't want them to lock up easily. Quote:
This vid shows how well correctly set up manual brakes work compared to a mis-matched power setup. Power brakes can work, but you need to know what you're doing to make sure they work correctly.
https://www.youtube.com/watch?v=EJIbq3PK_tk
#7 | |
Thanks theastronaut both posts very interesting and gives food for thought.
#8 | |
Quick question, using your power brake example that evidenced 893 lbs of pressure, is this then split at the proportioning valve at a 40/60 ratio back to front? So, 893 lbs of total pressure results in the front receiving 535lbs (60%) and the rear receiving 357.2lbs (40%) at 23 inches of manifold vacuum?
No problem! There is a lot of wrong/bad info out there on brake systems, and brakes are too important to get them wrong! I post what has worked for me with the math to back it up; magazines and brake companies are in the business of selling parts so of course they push "upgraded" parts.
#10 | |
Both front and rear circuits have the same pressure since both circuits are operating from the same size master cylinder bore, so the output pressure is the same front and rear. The proportioning valve limits the maximum output pressure to the rear to keep them from locking up. They have the same pressure during normal driving, but if you slam on brakes the proportioning valve limits total rear pressure. On factory drum/drum or disc/disc setups without a proportioning valve the staggered wheel cylinder/caliper bore sizes are made to balance front to rear braking power to keep the rears from locking up first. On modified systems (or even modified/staggered wheel/tire sizes) its a good idea to use an adjustable rear proportioning valve so you can get the most out of the rear brakes before they lock up. The generic "one size fits all" combination valves that come with most brake kits aren't ideal except for the one application they were initially engineered for, and may not let the rear brakes stop as hard as they could, or they might allow too much rear pressure and still lock up the rear too early. There are systems that vary front and rear pressure- race cars have brake pedal boxes that have two master cylinders, one for front and one for rear, and an adjustable balance bar that applies more or less pressure from the pedal into each master cylinder. That setup would vary pressure front to rear, and make for easy adjustments to dial in the front to rear balance. Some even have a dial on the dash that will adjust the balance bar on the fly. https://tiltonracing.com/product/900...edal-assembly/
| Bookmarks |
