Old 12-07-2023, 10:50 PM   #1
K10-Kansas
K10-Kansas's Avatar
is this long or short
Hi all. I was thinking of buying this truck and the owner has told be it is a short bed, but looking at the pictures, it's hard to tell. It's a 4 hour drive to go look at it. What do you think.
1971 C10 body. 76 4x4 chassis cut to short frame. Crate 350 2nd Gen small block. 4BBL Holley 4160. 4L60 transmission. ~ James
K10-Kansas is offline   Reply With Quote
Old 12-07-2023, 11:17 PM   #2
Getter-Done
Getter-Done's Avatar
Re: is this long or short
Both Pictures are in a (trigonometry) view.
A lot of sellers do this.
Here is the Specs for Square bodies 73-87 stuff
MODEL Wheelbase (6') Wheelbase (8')
Blazer 106.5"
C10 117.5" 131.5"
C20 N/A 131.5"
K10 117.5" 131.5"
K20 N/A 131.5"
C30 N/A 131.5
Crew Cab N/A 164.5"
Suburban 129.5"
Regular Cab
Cab & Chassis 135.5"
159.5"
159.5"
C/30
Motorhomes 127"
158.5"
178"
You got choices.
Ask the person to measure the WB.
The VIN# can tell you alot.
Or drive and look at it.
If it is a good price, you may regret your hesitation.
The early bird gets the worm,
85 Chevy K-20
Old 12-07-2023, 11:29 PM   #3
Willowrun
Willowrun's Avatar
Looks like a long bed to me. Below is a short bed. Similar angles. Gap between front of rear tire and rear cab is less than a door length on swb. Looks longer on truck you posted.
Old 12-07-2023, 11:35 PM   #4
Getter-Done
Great Pictures and Comparision.
85 Chevy K-20
Old 12-08-2023, 10:17 AM   #5
K10-Kansas
K10-Kansas's Avatar
Blazer 106.5"
C10 117.5" 131.5"
C20 N/A 131.5"
K10 117.5" 131.5"
K20 N/A 131.5"
C30 N/A 131.5
Crew Cab N/A 164.5"
Suburban 129.5"
Regular Cab
159.5"
159.5"
C/30
Motorhomes 127"
158.5"
178"
You got choices.
Thanks for the info. Good to know.
Old 12-08-2023, 10:19 AM   #6
K10-Kansas
K10-Kansas's Avatar
Thanks that's a good way to have him take a look at his. I sent him this picture and info. I'm also asking him for a side shot.
Old 12-08-2023, 11:25 AM   #7
K10-Kansas
K10-Kansas's Avatar
We confirmed it was a long bed. He said it was short,,,, then said it was long. That was almost a 4 hour pointless drive.
Old 12-13-2023, 11:01 PM   #8
cwcarpenter98
cwcarpenter98's Avatar
Looks like it was a long bed that the rear portion of the frame was cut when the flat bed was installed to make a "short bed"
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 350, Saginaw 4 speed
Old 07-21-2025, 03:12 PM   #9
Nick_R_23
Nick_R_23's Avatar
Just for future reference, this “mod” is common in the off road world. People will take a longbed truck and shorten it to shortbed length without moving the axle. You get the advantage of having a shorter body with a longer wheelbase, which allows you to go with larger tires further apart than a traditional shortbed, and also greatly increases your rear departure angle (angle you can leave a ditch/valley without dragging the rear bumper/frame/body.
Nick_R_23 is online now   Reply With Quote
Old 07-21-2025, 07:22 PM   #10
Getter-Done
This is so True.
I had a 76 Blazer that would go where Long bed trucks and some Short bed Trucks could not climb the hill.
When 4 Wheeling the Short rear Departure Angle is a Plus.
85 Chevy K-20
