Brake line diagram? Anybody have one?
OK .......I didn't take enough pics on the tear down and now I'm trying to install new brake lines..uh without guessing! Anybody have a overall brake line diagram?
Thanks, Showdog |
Restoration Virgin!
Re: Brake line diagram? Anybody have one?
try this thread
![]() http://67-72chevytrucks.com/vboard/s...d.php?t=355152 may I also suggest picking up a factory assembly manual....although its very unorganized, it has a great detailed diagram in there too....OH...I think they sale a searchable CD formatted one too... check ebay for one!!! Good luck and hope this helps ya!!!
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
![]() Join Date: May 2010
What year? 2WD or 4WD? 1/2 or 3/4 ton?
71s and 72s are different from the earlier trucks. I believe the 1/2 and 3/4 ton 2WDs are the same except for the rear axle lines, and the earlier trucks may have used different style clips to secure the lines. I have lots of photos I took of the original lines when I disassembled my 69 3/4 ton with a H-052 axle if you think they would help. |
Yikes! I guess I could at least list what I'm working on. It's a 67 short step with 72 suspension front and rear. Brake line are from Inline tube and for a 72 short step.
Many Thanks! Dog |
Thanks Geoff!
The pics should help me get started! Dog |
![]() Join Date: Apr 2010
Here are the lines I just got from inline and where they go. If you need more pictures let me know. Wayne
You will have to change up the rear a little. The 72 hardline snakes around the cross member and has a hose that attaches on a small bracket that is mounted with diff cover bolts. The 67 hard line ends on the frame side rail. Easy to fix you just have to work with what you have. here is a picture of a 71/72 rear
Many Thanks!
The pics should really help! This site is the best...Thanks for helping out a rookie! Mike |
gysgtc, have you installed the lines that come down from the prop valve to the frame? I was planing to buy a kit from Inline Tube (CTB67D4), but when I called Inline Tube they were unable to say for sure if this kit went inside or outside of the frame rail. I am trying to make sure these go outside of the frame and not inside. Any more pics you have would be helpful.
Thanks |
No I have not but if I have time today I will check them out and let you know. Sorry was out of town and didn't see your post.
Fasttech, here is a picture of the lines that run to the valve. They run on the outside of the frame. When I ordered mine from inline I just told them it was for a 67 c10 with front brake conversion. Let me know if you need any other pictures. Wayne
Great pic thanks Wayne! This is certainly outside the frame. Very important to keep heat from the headers away from the brake lines. If you have time can you post the Inline part number(s) you purchased?
Sorry I don't have a part number. I just called them and told them I wanted the complete set for a 67 long bed with front disc conversion. I bought the stainless set. If I have time later today I'll dig thru my box of receipts and see if I can find a part number for you.
The part number for a 67 C10 long bed stainless with disc brake conversion is SCTB67D3.
#15 |
this helped a lot..............better than INLINE could do.
SOLD -77 CHEYENNE SWB, LS SWAPPED -1976 SILVERADO YUBA GOLD/NEUTRAL (2-TONE) |
#16 |
#17 | |
Posted via Mobile Device |
#18 |
Ts were all seperate purchased
#19 | |
Thanks Gayle |
#20 |
hello guys, rookie builder here.
I was very thankful to stumble on this thread. this is right where i am with my pick up. is everybody pretty happy with the Inline product? i too did the disc conversion on my67 SWB thank you guys for all of the pictures!!!! |
#21 |
Good info here...
1966 C10 "Mary" 1967 C10 Custom "Ole Blue" 1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364 1979 C10 Silverado "The BIG TEN" C10 Club Texas -HMIC |
| Bookmarks |
