Old 07-26-2025, 01:47 PM   #1
JSchwagerl
New Member
Converting 72 door panels to metal?
I want to convert my 72 plastic inner door panels to the 67-71 metal style. Anyone complete this and have a parts list? I am guessing I need the metal screws and new armrests? Then I need to figure out how to change from the plastic door panel push pins to the screw holes for the new metal panels?
JSchwagerl is offline   Reply With Quote
Old 07-26-2025, 02:09 PM   #2
Richard
Re: Converting 72 door panels to metal?
Using the panel itself and upper trim piece as a template for screw holes should be easy enough. Note you will need new window regulators and door controls as the handle shafts are longer on the 72. If they are not changed the handles will stick out from the door panel 1/4"-3/8"
Richard
Old 07-26-2025, 02:20 PM   #3
JSchwagerl
New Member
Richard, are the metal screws on the 67-71 just screwed right into the door itself? I don't see any other clips or hardware listed on LMC.
Old 07-26-2025, 02:50 PM   #4
RustyPile
RustyPile's Avatar
No, sheet metal screws are not used for this. Special 1/4 X 20 nuts are welded to the steel door. These nuts are called Projection weld nuts, available at most hardware stores.
RustyPile is offline   Reply With Quote
Old 07-26-2025, 02:50 PM   #5
72c20customcamper
72c20customcamper's Avatar
The panel screws are machine screws the screw into nuts mounted on the door . Most likely easiest way to do it is to use rivet nuts . The armrest would be the same deal
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 07-26-2025, 03:09 PM   #6
JSchwagerl
New Member
Perfect. I found a rivet nut kit on Amazon. I want to make sure I have all the parts here before I tackle the project after Hot August Nights.
Old 07-29-2025, 12:52 AM   #7
'68OrangeSunshine
'68OrangeSunshine's Avatar
Actually they are spring clip nuts. Squeeze the spring and they detach from the door body. Ace Hardware bin item. 1/4-20 is correct.
Old 07-29-2025, 08:42 AM   #8
72c20customcamper
True but making a square hole and in the right spot is more work than rivnuts. I had to replace a couple on my 68 and used the ones you mentioned.
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 07-29-2025, 04:24 PM   #9
'68OrangeSunshine
Admittedly, I am not familiar with the MY '72's door anatomy. A small rectangular box for each clip nut exists in the '67-'71 doors.
Sorry for butting in.
