![]() Join Date: Jul 2001
Quick Change Chrome V/C Studs - 2 Sets
LOWERED PRICE - $15 PLUS SHIPPING
Doing a bit of garage and shop cleaning today and came across these. Used them when I was running a General Kinetics solid lifter camshaft in my '57 during it's 1/4 mile days. Worked great when having to remove the valve covers rather frequently to re-set the lifters with a solid lifter cam after several runs. (Anyone remember General Kinetics cams? Used to be quite popular at one time) 1/4'' - 20 threads with 3/8'' dia. shank, 4 3/8'' total length and will fit all first generation SBC cylinder heads with side of flange valve cover mounting. Also gives a nice custom look for a clean show engine setting. Two full sets each consisting 8 studs per set w/ one extra stud per set and 8 quick release cap tips w/ 3 extra tips per set. Use some 0000 fine steel wool for a quick clean. $15 per set plus shipping, money order payment, do not have Paypal. Dang it, can someone smarter than I at computers do a flip the pic for me, LOL?
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks Last edited by Ironhorse; 07-28-2025 at 09:41 PM. Reason: Pic needs flipped / Price Reduced |
![]() Join Date: Dec 1999
Re: Quick Change Chrome V/C Studs - 2 Sets
Okay
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
Thanks for the assist Richard, have not learned how to do that after the pic is posted.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
Lots of looks, lowered price to $15 plus shipping.
#1 tip, do not post from phone. Transfer pics to computer. Simply transfer with something like photos. Open with Paint and edit to your liking, if pic looks okay just click "save as" to overwrite the original. I usually crop many photos to make them smaller but it is not always necessary. Always look at the preview to see what post looks like. You can go to edit, delete the the photo and upload the new one if that was not done.
![]() ![]() ![]() Join Date: Jan 2018
What’s the length of the threaded portion? I’m running these valve covers for my 81, but I keep forgetting to take a measurement of the bolt length I need
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 350, Saginaw 4 speed "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
#7 | |
Ah dang, I just measured and the bolts I have that fit are 1” long. The typical bolt size is too short due to that extra bump where the bolt goes through. Thank you for getting that info though!
![]() Join Date: Jun 2005
Most of those hold downs have a removeable stud. You screw the stud into the head and just twist the top part of the hold down to remove them. All that would be needed is longer 1/4-20 studs.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Sliding Rear Window Power Windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
Thanks for the info and the bump but I don't believe these have the removable studs. Not sure but think they might be Mr. Gasket brand? Mr. Gasket was quite a popular aftermarket brand when I ran my '57 thru the 1/4 mile.
Still available, $15 per set plus shipping.
Ba Bump to da top
| Bookmarks |
