Old 07-29-2025, 08:37 AM   #2
Lost in the 60's
Lost in the 60's's Avatar
Re: Another C10, 1970 this time
So, the left door is a replacement and I like the scroll pattern along the top, but all I see for replacement panels has wood grain there. Anyone know what year/model truck is this from ?
The right door was stuck shut so I removed the seat, which all 8 bolts came out with little issue. Then the 4 door panel screws came out nicely, with only one putting up a mild argument for a short time. Very pleased with those results. Soaked the latch as best I could from the inside with Deep Creep and after 5 days, I was finally able to work the door open with a little gently prying and lots of back and forth 1/4-1/2" movement. Not surprised, but disappointed that the right door bottom is pretty much gone. I could see a hole at the front from the inside and with the left door being a replacement, suspected this door would be rough. Fortunately, the right door on the OK parts truck is really nice and will end up on here.
Lost in the 60's is offline   Reply With Quote
