Old 07-30-2025, 11:01 PM   #11
val1gonzales
Re: Headman Header Brackets - Alternator Location
Are you running the original heads for the 283 engine? Or are you using a newer set with the bolt holes on the front side for brackets. If so you can do as I did with a head mounted bracket for alternator. I wanted a "factory" look with original short water pump.
val1gonzales is offline   Reply With Quote
