Old 06-23-2024, 07:18 PM   #1
pjmoreland
pjmoreland's Avatar
Vacuum Gauge Installation
Here's a short video that gives an overview of the method I use to install a stock-style (reproduction) vacuum gauge in a factory gauge cluster. The only purchased items are the gauge and the decal material.
https://youtube.com/shorts/W6D0dcKrsCc?feature=shared
pjmoreland is offline   Reply With Quote
Old 06-23-2024, 10:01 PM   #2
'68OrangeSunshine
'68OrangeSunshine's Avatar
Re: Vacuum Gauge Installation
Cool. I have a Moon Eyes Vacuum gauge on 919. Bought it in '77 after breaking in my first 292 build. Invaluable gauge when tuning up, a real eyeball on the engine's health when cruising. Also the first indicator of a broken exhaust valve spring.
My nominal with a .030-over 292 is 17.5''Hg. [SBCs with greater displacement might have more Suction.]
Jumps into the 20s when engine-braking.
Drops low on acceleration.
Bouncing needle tells you a valve or lifter is blown.
On a long cruise, you can see if you're getting better economy by easing the acellerator pressure and decreasing RPMs without dropping your Inches of Mercury.
It's the Steam Gauge OBD.
Have one for the '71 Jimmy that I haven't put on yet. An AutoMeter.
Old 06-23-2024, 10:28 PM   #3
Getter-Done
Getter-Done's Avatar
That is Cool.
So, you made your dimple dies out of delrin?
The early bird gets the worm,
85 Chevy K-20
Getter-Done is online now   Reply With Quote
Old 06-23-2024, 10:34 PM   #4
pjmoreland
pjmoreland's Avatar
I like having a vacuum gauge. Might not be the most useful gauge on the dash, but it can't hurt.
Old 06-23-2024, 10:41 PM   #5
pjmoreland
pjmoreland's Avatar
Originally Posted by Getter-Done View Post
That is Cool.
I designed them using SolidWorks and then had them 3D printed out of PLA. The gauge cluster metal gets bent at 90 degrees at the bottom of the opening with a sharp corner, and 72 degrees at the top with a large radius. It was an interesting challenge to model that accurately and have the two bend profiles blend together smoothly.
I put grease on them during use, and they form the metal very easily. I'm not seeing any wear on them at this point.
Old 06-23-2024, 11:05 PM   #6
Getter-Done
Yes, I noticed the profile differences.
Great work.
I may try this with some delrin.
Thanks for the Idea.
85 Chevy K-20
Old 06-23-2024, 11:06 PM   #7
Cwood0425
Looking Good
Cwood0425 is offline   Reply With Quote
Old 06-24-2024, 07:45 AM   #8
1970cstblazer
1970cstblazer's Avatar
Thumbs up Re: Vacuum Gauge Installation
You are definitely a craftsman. Very nice work.
Old 06-24-2024, 09:54 AM   #9
pjmoreland
pjmoreland's Avatar
Thank you
Old 08-14-2025, 10:57 PM   #10
70 gmc c2500
Junior Member
Any chance I can get a dimple die from you to do my son's cluster, maybe rent the one you made or something?
70 gmc c2500 is offline   Reply With Quote
Old 08-15-2025, 12:01 AM   #11
pjmoreland
pjmoreland's Avatar
Where in CA are you?
Old 08-15-2025, 01:05 AM   #12
70 gmc c2500
Junior Member
I'm in the SF bay area, Fremont to be exact and my son is in Pleasanton.
Old 08-15-2025, 04:29 PM   #13
pjmoreland
pjmoreland's Avatar
I've attached a stencil PDF I made by crushing a factory tin flat and tracing the resulting hole. I cut this opening as follows:
1) Place the stencil face-down on the front of the tin
2) View the tin from the back and line up the marks on the stencil with the notches in the tin
3) Very carefully flip the tin back over without moving the stencil and trace the opening with a pencil
4) Drill 5/32" holes at the corners
5) Use a cutoff wheel on a Dremel to rough-cut the opening
6) Hand-file the opening up to the line
This is all shown in the video I posted earlier in this thread.
Old 08-17-2025, 09:41 AM   #14
OL SKOOL
OL SKOOL's Avatar
Nice work looks factory.
OL SKOOL is offline   Reply With Quote
Old 08-17-2025, 10:06 AM   #15
pjmoreland
pjmoreland's Avatar
Thank you
Old 08-24-2025, 09:40 AM   #16
1970cstblazer
Lightbulb Re: Vacuum Gauge Installation
I don't have access to the die to make the cut opening perfect. I have a few non-tach vacuum cluster tins. I spliced/welded an original vacuum tin section into my tach tin. I used Patrick's vacuum decal on the original tach lens. I wnr with a repro vacuum gauge made by Counterpart. The finished product looks OEM.
