Old 09-05-2025, 10:24 AM   #2
scottofksu
scottofksu's Avatar
Re: 1960 chevy truck wiper motor mounting grommets
Hopefully someone comes along with a source to a genuine replacement part. In the event that someone doesn't, I have a potentially novel solution for you... Though I can't remember the project, I had a similar need and found Subaru Valve Cover grommets to be a useful solution. They have a metal face that makes a good washer and then a rubber backing similar to the grommet you showed for the original.
Here is an example:
https://www.subaruparts.com/oem-part...NyoTpAZN9bX4Tg
Travis' Tribute Truck - 65 C10 Frame Up Restoration
http://67-72chevytrucks.com/vboard/s...d.php?t=495073
scottofksu is offline   Reply With Quote
