![]() Join Date: Sep 2007
72 half ton frame cuts amd disk brake suspension complete
Finally i was able to get to the 72 longed frame amd make some cuts...
Front frame horns amd cross member. 50.00 plus ship. Trailing arms 150 plus ship Auto transmission cross member 60 plus ship. Complete steering and disk brake front end with ps gearbox. 300. Local pickup only 5 lug coil spring dog leg rear end. 300.00 local pick up. 3:73 Rear frame horns 10.00 each. Just tell me what you need off the frame. Coil spring cross member amd frame supports sold
1967custom |
Re: 72 half ton frame cuts amd disk brake suspension complete
PM sent on the frame horns
Chad |
1967custom |
Pics of the frame horns. I'll cut the crossmember off and sell seperate
1967custom |
All still available except for the rear end crossmember
1967custom |
![]() Join Date: Feb 2009
Do you have the bed mounting brackets?
I do actually which ones are you needing?
1967custom |
All four bed mounts for a 72. I sent pic to your phone if you still have the same number
Scott |
| Bookmarks |
