Old 09-22-2025, 06:02 PM   #1
1970 CST
1970 CST's Avatar
Help Identifying Block
My truck which is supposed to have a 350 currently has an older 305 in it. While scanning FB market Place I saw an ad for a 350 engine out of a 1970 Chevy pick-up. I picked up the motor, less an intake for $250. Looking over everything I am confused by the numbers.
Casting - 3970010
Center of Block below intake - M (in a square) followed by 6
R/F of Block - K11 05 TBB
The question I have is the TBB can either be a 1970 C10-3500 or a 1979 C10-2500?
On the right side of the block there is the following.
A 1
D < N
Any help would be appreciated.
1970 CST is offline   Reply With Quote
Old 09-22-2025, 09:10 PM   #2
basketcase
basketcase's Avatar
Re: Help Identifying Block
3970010....302.....69....4 bolt...Z-28 Camaro (Not likely what you have)
3970010....327.....69....2 bolt ...Trucks and industrial
3970010....350...69-80...2 or 4 bolt car or truck (most likely)
You need to post the casting number to determine the age of the block. It is on the bellhousing flange in the same position as the casting number but on the passenger side.
'69 swb stepside in progress.
'59 Corvette lifetime project
basketcase is offline   Reply With Quote
Old 09-22-2025, 10:05 PM   #3
1320NUT
1320NUT's Avatar
3970010
69-79
302/350
car & Truck 2 & 4-Bolt Most common
1320NUT is offline   Reply With Quote
Old 09-22-2025, 10:24 PM   #4
1970 CST
1970 CST's Avatar
This is the only thing on the right side back of the block. Other than this I posted the casing numbers on the right side of the block.
Old 09-22-2025, 11:01 PM   #5
1320NUT
1320NUT's Avatar
what is the stamping, on the passenger side, on the front of the block, above water pump port? part of it, will be the vin number, and the other will tell more about the block?
Old 09-23-2025, 06:43 AM   #6
1970 CST
1970 CST's Avatar
K 11 05 TBB According to the charts I’ve seen it could be a 1970 or a 1979 350 block. Not sure how to determine which?
Old 09-23-2025, 08:10 AM   #7
1320NUT
1320NUT's Avatar
snap a picture of the pad above the water pump if its a short pad its a late block if its a long pad its a early block?
Old 09-23-2025, 08:57 AM   #8
1970 CST
1970 CST's Avatar
Attached
Old 09-23-2025, 09:15 AM   #9
1320NUT
1320NUT's Avatar
Early block for sure let me see if I can do something with those stampings
Old 09-23-2025, 09:28 AM   #10
1320NUT
1320NUT's Avatar
TBB
1970 350 cv/fd cab, m/t 3sp 255hp 4bbl C-10 to 3500
St. Catherines, Ontario was the foundry. (McKinnon Industries Canada)
Old 09-23-2025, 10:27 AM   #11
1970 CST
1970 CST's Avatar
Thank you, I couldn’t figure out how to differentiate between the 1970 and 1979. Super glad it’s a 70. My CST currently has a 67-68 305 in it. I think this one will be a nice change when I’m finished with it.
Old 09-23-2025, 11:02 AM   #12
1320NUT
1320NUT's Avatar
Have you torn down the Facebook engine? look at the crankshaft number it will tell you if its a 350 or not I believe the last three numbers are 442?Early Chevrolet 350 crankshafts can have casting numbers such as 3932442
Old 09-23-2025, 11:48 AM   #13
Originally Posted by 1970 CST View Post
T..... My CST currently has a 67-68 305 in it...............
305 V8 wasn't available till 1976. More than likely you have a 307 (68-73) or 283 (67 and older). I always had good luck with the 307s. I think visually the 283 had the oil fill tube in the intake and the 307 use valve cover oil fill. That's if they are stock. Good luck with new engine. The 350 should add a bit of zip to it.
Old 09-23-2025, 01:28 PM   #14
MJN
MJN's Avatar
Is it just my eyes or do you have fine thread bolts threaded into the bellhousing bolt holes?
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 09-23-2025, 02:30 PM   #15
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
I don't see any black paint on this. When did GM start painting the engines black at the factory?
~Steven
Simi Valley, CA
Old 09-23-2025, 02:39 PM   #16
1320NUT
1320NUT's Avatar
Starting painting engines black in 1988 when throttle body fuel injection came out
Old 09-23-2025, 02:51 PM   #17
MJN
MJN's Avatar
Black painted engines started in the late 80's (1987ish)
'17 GMC Yukon XL
VCCA member #58596
Old 09-23-2025, 03:49 PM   #18
Steeveedee
Steeveedee's Avatar
OK, so I was hoping to eliminate the newer year by color. Didn't work.
~Steven
Simi Valley, CA
Old 09-23-2025, 04:20 PM   #19
1970 CST
1970 CST's Avatar
3/8 course, you're seeing the 2" adapters I made out of 3/8 black pipe to get clearance from the engine stand.
Old 09-23-2025, 04:26 PM   #20
1970 CST
1970 CST's Avatar
My mistake, the casting number on the engine that is currently in the truck is for a 307, although the intake and Valve covers are from a 327? Haven't looked at the head casting numbers. Frankenstein motor.
Old 09-23-2025, 04:28 PM   #21
1970 CST
1970 CST's Avatar
Might start tear down tonight, see what I find.
Old 09-24-2025, 02:26 PM   #22
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: Help Identifying Block
The engines in both my 1984 K/5 Blazer and Caprice with 305 were black.
Old 09-25-2025, 01:53 AM   #23
67 twins
Location: Herculaneum MO (20 minutes south of St. Louis
TBI came out in 87 not 88
67 C10 283 T5 swapped longbed fleetside = wife's daily driver(divorced)
67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck
67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD(Sold)
72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck(divorced)
73 El Camino SS 454 4 speed my first big block
Can you tell we are fans of longbed fleetsides & 67s
Chris
67 twins is offline   Reply With Quote
