Old 08-06-2025, 11:05 PM   #201
ryans69chevy
Re: Fashionable Fever! - 1969 Chevy C10 Build
Here's some more. Going to fish a pull string up for cab lights before welding the outer roof skin.
ryans69chevy is online now   Reply With Quote
Old 08-19-2025, 10:19 PM   #202
ryans69chevy
Outer roof skin all welded up. Still have to take a roloc to the back seam welds to clean them up. Turned out better than I thought. Took it nice and slow to avoid major warp.
Only thing not too impressed on is above the doors - filling in the spot weld holes didn't turn out as good as I hoped. I couldn't reach down in that valley up against the drip rail very good with my welder. It will all get filled in with seam sealer eventually, just wish I could have filled them in a little more. When I took my roof off originally, I used a 3/8" spot weld cutter, so I had that large of hole to fill back in.
Now on to cab corners and rockers...
Old 08-19-2025, 11:50 PM   #203
Kronald_70GMC
Kronald_70GMC's Avatar
Nice work! Looks good 👍
Kyle
1970 GMC "Project Splice"
2017 Yukon Denali (Daily Driver)
Kronald_70GMC is online now   Reply With Quote
Old 08-30-2025, 10:18 PM   #204
ryans69chevy
Thank you sir.
Spent bits and pieces of the day working on rocker fitment and realigning my doors and all that. Kept getting frustrated. Had to step away a few times. Watched some videos and read through some threads on here. Might have to rework some of the stuff I did a few years ago - doesnt look like its fitting that well.
Old 09-18-2025, 06:01 PM   #205
ryans69chevy
Finally came up with a plan on my rocker. Still not 100% sure how I needed to move it so much.
I installed my door and aligned it the best I could, but couldn't get my rocker to fit where it needs to. After some time measuring, I found out I needed to move my rocker down 1/4", but my inner rocker wouldnt allow it. Ended up cutting my inner rocker out and adding a 1/4" of metal to lower it. Would have liked to bend a whole new inner rocker, but my metal brake is only 30" wide. Pic shows the inner tacked in. Looks like the outer will work - now time to weld it in fully.
Old 09-23-2025, 08:11 PM   #206
nicklear36
nicklear36's Avatar
I had the exact same problem. I had to move my inner rockers down more than an inch to get the door to close. It was frustrating to say the least!
nicklear36 is offline   Reply With Quote
Old 09-30-2025, 10:30 PM   #207
ryans69chevy
Holy moly. Here I thought I messed something up with being 1/4" off. Must be somewhat of a common issue?
Old 09-30-2025, 10:45 PM   #208
ryans69chevy
Got at it a little bit this past weekend. Finished up welding the inner rocker in place and getting my outer rocker where it should be. Tacked all the slices before taking it out to fully weld.
I installed my door again and now I am running into another issue with the striker plate. With the striker off, the door lines up with the body lines (3rd pic), but when I put the striker on, the door moves up maybe 1/8"-3/16" which makes the body lines not match up.
There is not much adjustment in the striker. Ive tried moving the latch that is bolted to the door, but that also has little adjustment in it. The only thing I can think of is making the holes for the bolts on the striker plate larger or elongated in hopes that it can move down more. Ive searched the board here and can't come up with anyone ever having to do that. I've read about someone filing down a little of the striker, but not sure thats the solution here. Is there another way that I'm just not seeing?
Old 10-01-2025, 06:47 PM   #209
nicklear36
nicklear36's Avatar
I would try elongating the holes on the striker plate first. Those can be replaced easily if you need to
Old 10-01-2025, 08:19 PM   #210
ryans69chevy
Thanks for the suggestion. I just looked them up online - amazing all the stuff they make for these pickups. I will give it a try elongating the holes.
Old 10-01-2025, 10:05 PM   #211
72 tigger
72 tigger's Avatar
Nice craftsmanship on your repairs
71 C10
72 K20
72 K10 Super
Kirk
72 tigger is offline   Reply With Quote
Old 10-02-2025, 07:16 PM   #212
ryans69chevy
Thanks. I enjoy the process. Gotta invest in some knee pads or something now that I'm working on my knees so much with the rocker and cab corners. I built my cab dolly too low.
Old 10-02-2025, 08:44 PM   #213
Getter-Done
Getter-Done's Avatar
If you have a TSC in driving distance, I found a Great kneeling pad.
Here's the Link: https://www.tractorsupply.com/tsc/pr...nkp-56-2213418
I bought one at Harbor Freight it was okay, But very firm for work like this.
The early bird gets the worm,
85 Chevy K-20
Old 10-14-2025, 11:02 PM   #214
ryans69chevy
Thanks for the suggestion. We do have one in the area, its just a PITA to get to from where I am as construction is rampid. There is a Ace Hardware close by. I checked their website - $10 for one. I might give that a try.
Old 10-14-2025, 11:21 PM   #215
ryans69chevy
Holy moly - finally got the outer rocker in. Had it all epoxied and ready to go this weekend. Was about to weld it in when I realized part of the rocker wasn't touching part of the pillar right next to where the cab corner meets up. Ended up slicing the pillar and bending it out and welding in more metal. Ended up being off 5/16" in a matter of 7". Fits really good now.
Im going to have to wait until I flip my cab to weld the inner rocker to the outer rocker at the bottom lip - my dolly stand is just too low to slide under there and do any work.
Now onto my cab corner (or back onto it). I wish I wouldnt have done this corner a few years ago. I put it in before my rocker thinking it would turn out fine - well now its not lining up with the rocker. Thats why they say do the rocker first i guess. Last two pics shows how out of whack it is. Might be easier to just make a cut the whole way up in the back and see if i can fit it in better instead of taking the whole corner piece out again.
