Old 10-08-2025, 06:14 PM   #21
SDRRACING
SDRRACING's Avatar
Re: Help With Front Fender Tire Rub
Yahoo. Fender rub fixed. Thanks jweb for the tip on the Eastwood fender roller tool. That thing worked great. For you builders I highly recommend you adding this to your tools. When you get it figured out it works great.
I installed the correct length shocks for the Global West extended travel control arms plus I installed a 550 lb spring. The 450 lb was just too soft. Now I got to get this to a good alignment shop near me and than install the sway bar from Global West. Thanks you guys for the help. Much appreciated.
https://www.eastwood.com/ew-fender-r...8aAoR7EALw_wcB
SDRRACING is offline   Reply With Quote
