Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 10-01-2025, 11:03 AM   #1
ullose272
leaf spring vs trailing arm
I have a 68 GMC with leaf springs that should be high 11s low 12s, it needs a rear suspension makeover. it would either be new rear leafs, spring under axle, with caltracs or convert to trailing arm and probable coilovers. this will be street/strip. Opinions?
ullose272 is offline   Reply With Quote
Old 10-08-2025, 07:02 AM   #2
MellowYellow70
Re: leaf spring vs trailing arm
Are you going to use this as a race only, or as a street truck/race setup?
My 70 is a trailing arm truck. So with all the modified rear trailing arm suspension I have to use a removable airbag plate system I designed for hauling all my crap from track to track on Drag and Drive events.
That being said, good bushings, good appropriately sized leaf spring packs, and Calvert or Assassin traction bars with.......... GOOD shocks front and rear get my vote.
If patience is truely a virtue, Then I am so screwed
1970 Chevy SWB Gasser 364"LS and all the goodies
2001 Vette Road/Street
1990 IROCZ Vert
MellowYellow70 is offline   Reply With Quote
Old 10-08-2025, 08:59 AM   #3
Rickysnickers
Rickysnickers's Avatar
While not directly related to the discussion, are you bringing it out to the Halloween Classic this week?
Old 10-09-2025, 12:15 PM   #4
ullose272
Im not, i think ill go out to the last blast next weekend.
Old 02-24-2026, 07:15 PM   #5
I_Wanna_Go_Fast
Hey - I'd be curious to learn more about that rear suspension set-up... I do a lot of drag and drives with my 72 trailing arm truck and am always looking for better options!
I_Wanna_Go_Fast is offline   Reply With Quote
