#26 |
Re: Post pic of suicide door or CUSTOM crewcab hinges
NEW VIDEO DROP!!! https://youtu.be/RBlaW8s_Dik?feature=shared
#27 |
New video in editing, hopefully today to be posted. Also there is a fun video already posted of my kids helping disassembling the Duramax and then bailing to eat before finishing, sadly ran out of memory to finish the vid https://youtu.be/w3XGvjTxLP0
#28 |
Preview of the video hopefully coming out today
#29 |
Tried to post 2 more pics, but getting security token missing messages
#30 | |
![]() Join Date: Dec 2009
Another thing I have noticed is that if the picture is taller than it is wide it tends to flip the picture sideways.
________________________________________________________________________________________ ____________________________________________ The early bird gets the worm, But the second mouse gets the cheese 85 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
#31 | |
Also New Video has dropped........https://youtu.be/0XOrbc25Nj4 Edit it worked! Thanks Getter-Done! |
#32 |
mmmmmm
#33 |
Glad to hear that worked for you.
![]() If you delete the S in the you tube link it will look like this below.
#34 | |
PS: Since the time the pictures were taken, I am 5/8" forward/backwards and 1 1/4" vertically out from the final location! Gotta buy C25 and 100% Argon and get the tig welder out of its long hibernation SOOON!!! |
#35 |
Very nice work and planning.
![]() Trial and error is real. You got this project going in the right direction. ![]() ![]() ![]() ![]() ![]() ![]()
#36 |
Fighting for getting 16th of an inch lower at this point, could leave it here or after another 1/8 inch or so down which is max without having to really retink the floor and upper mount of the inner fenders. Side to side is good, front to back is good, but would like to go lower! I got time as my 250 bottle I am changing from oxygen to C25 and both it and my 125 1962 Civil Defense {anybody remember nuclear drills in grade school?} bottle are out of cert and it will take a week the shop said (was willing to loose this cool bottle if I could get 250 bottle...but they said no way!)and will be a week......I don't know about you but I always run out of gas right when things are speeding up! Maybe God is doing this so I can slow down and rethink everything going forward.
On another note, if you want to copy my plan, if you go with a 2 to 2 1/2 inch shorter rear door the front wheel would center in the wheel well. QUESTION: Final trimming on the rear panel will have either a 1/2 to 3/4 spacing between the dmax and 66 corner panels ooorrrr shaped in a crescent on the edge of the dmax panel as is stock on the 2008. First way is stronger, the only reason not to is for not letting rain water drain and start rust in the veeeerrrry long future (I plan to pass this truck onto my kids once I absolutely can't drive anymore) I might be over thinking this..... |
| Bookmarks |
| Tags |
| crew cab, hinges |
