Old 10-20-2025, 10:59 AM   #351
A1971Blazer
A1971Blazer's Avatar
Re: Doing LS Swap - I have no idea what I'm doing!
Congratulations on getting it back on the road. Five years really isn't too terribly long now that it's behind you!
I finished my '67 in the spring of '24 and have enjoyed every minute of the driving experience since.
You will love the LS!
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 10-21-2025, 11:54 AM   #352
kev2809
low n' slo
kev2809's Avatar
congrats! i know that felt good!
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 10-24-2025, 03:40 PM   #353
EagleChief
EagleChief's Avatar
Thanks everyone! It was definitely a fun few days - even just looking out the front door and seeing the truck back in the driveway (instead of up on jack stands in the garage) made me smile.
I drove it to work yesterday (52 mile round trip). The weather was perfect, the sun was out, 72 degrees... *chef's kiss*
Obviously still have a lot to do. Need to start working on the interior now. I'll probably revive my build thread I had going - before I started this one - and keep track of everything over there. It'll probably take longer to do that stuff than it did to get this thing back on the road.
1971 C10 - Hugger Orange/White
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=780197
LS Swap Thread: https://67-72chevytrucks.com/vboard/...d.php?t=811460
EagleChief is offline   Reply With Quote
Old 10-27-2025, 04:44 PM   #354
EagleChief
EagleChief's Avatar
Here's a list of the main items done at the mechanic: Basically putting this in here for record keeping. I added to my build thread, but thought I'd put here as well for the LS Swap crowd.
List of things completed at mechanic:
New Pinion Seal
New 1350 Yoke
Gear Oil
Posi Additive
New Output Seal
New 1 piece H-D Driveshaft
New Solid U-Joints
Transmission Fluid
New transmission cooler lines and fittings -6AN
Transmission oil cooler
New hard fuel lines
Fuel tank mounting
New hardware
New fuel filler fabrication
New Aeromotive EFI Fuel Pressure regulator with gauge
New fuel filter
Dumby Cab Fill
Mass Airflow Sensor
Cold Air Intake
New Power Steering pump and hoses
New Drive belts
New heater hoses
New Moraso Overflow Tank
New spark plugs and wires
ICT oil sender & adapter
ICT Temp sender & adapter
New ACDelco O2 sensors
Full 2-1/2" exhaust with X-Pipe
18" Flowmaster mufflers
New battery & holder
Custom battery cables & wiring w/ loom
Sealed firewall with grommets and fill in leftover holes w/ patches
2 oil changes
