Old 08-31-2004, 06:20 PM   #1
Madbomber88
Active Member
Madbomber88's Avatar
Need help diagnosing problem
I have a problem with my rear end... Nice intro huh?
Only when I am starting from a stop, with the wheel turned anything but straight, in other words, this only happens when I am pulling onto a road.
Something in the rear is binding or whatever, and it clunks for the first few seconds of the acceleration, but it is pretty hefty because it feels like it is kicking the whole rear of the truck from side to side until it frees up. This doesn't happen if I am starting from a stop and going straight.
It's a 71 K5 CST, no lift, SM465, 350 stock
Any ideas?
71 Blazer CST
72 K20
Capt USAF
Madbomber88 is offline   Reply With Quote
Old 08-31-2004, 07:13 PM   #2
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Do you have a posi rear? Have you checked the fluid level in the differential?
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 08-31-2004, 09:47 PM   #3
Madbomber88
Active Member
I have no idea if it is a posi. Is there a way to check without pulling the cover? I do need to check the fluid though. Could it be that simple and also be the reason for the noise??
71 Blazer CST
72 K20
Capt USAF
Old 08-31-2004, 11:21 PM   #4
Aarons'72Blaz
if it is a possi you might need a possi additive. if it isn't your spider gears could be striped or broken. best bet is pull the cover and have a look. the longer you drive it the worst it will get.
Aarons'72Blaz is offline   Reply With Quote
Old 09-01-2004, 11:43 AM   #5
bouncytruck
SKINNY TIRES RULE!
I would pull the cover and take a look. Sounds like it could use a fluid change anyway. It might just be low on fluid or be gummed up. How long have you owned the rig?
I think there is a way to tell buy either the codes on the glove box or the tag on the diff cover if it is a posi (factory anyway).
Aarons'72Blaz - welcome to the board. Take a minute to fill out your profile so we all know where you are
I think
bouncytruck 1972 K5
Old 09-01-2004, 04:00 PM   #6
Big J
Its lookin' like a Blazer!
Big J's Avatar
Is it a clunky noise or a more precise ratcheting noise? It almost sounds like you might have a lockrite in the rear diff. Its a posi unit that fits inside the rear diff and replaces the spider gears. Your probably going to have to pull the cover. It never hurts to change the fluid anyway. You can pick up the gear oil and additive (if you have a factory posi) at any parts place. Advanced auto is the cheapest around here.
BAZINGA!
My Build
Big J is offline   Reply With Quote
Old 09-01-2004, 07:19 PM   #7
Madbomber88
Active Member
I haven't pulled the cover yet but I do now know that it came from the factory with a Posi unit. Does that help any? I would say the noise is most similar to a binding noise, kind of hard to explain, It appears to be coming from the left side more than the passenger side but that may just be because that's where I sit...
71 Blazer CST
72 K20
Capt USAF
Old 09-01-2004, 07:52 PM   #8
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
LOOKS LIKE UR GONNA HAVE TO PULL THE COVER
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
