Old 09-01-2004, 06:59 PM   #1
dennis111
dennis111's Avatar
Which ball joint-disc conversion?????
Hopefully an easy answer. I have a set of 78' 1/2 ton spindles that I want to install on my 68' 1/2 ton a-arms.
Which ball joint should I use for both the upper and the lower a-arm, the 71-72' style or the 73' and up? Will I need to change the a-arm to a newer version to complete this conversion?
Thanks!
Dennis
68 GMC SWB Custom 1/2 ton, 2WD, 350 V8, PS, PB, 3-Speed, 3:08 12 bolt rear, tilt, tach, vac, cruise and more. . . .
dennis111 is offline   Reply With Quote
Old 09-01-2004, 08:49 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Buy the ball joints for the 78 spindles and install them into your stock arms. They interchange without any mods required.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
