Old 11-03-2025, 09:29 PM   #1
Gotenntitans
Gotenntitans's Avatar
GM Key Blanks
My Dad’s 87 GMC had two sets of keys from the factory. My wife drove the truck yesterday and bent one ignition key, which was the main one Dad had been using all this time. It was thin. I want another ignition key that’s a GM blank. I see they’re readily available on eBay.
My question is does it matter which blank?
The ones we have are silver. The keys we had for the 90 GMC we had were black.
Can I buy a wrong blank?
GoTennTitans
1987 GMC Sierra
1990 GMC Sierra (stolen)
2003 Chevy Silverado
Gotenntitans is offline   Reply With Quote
Old 11-04-2025, 08:38 AM   #2
chrismoore701
chrismoore701's Avatar
Re: GM Key Blanks
Look close at your key, there should be a small letter stamped in the key, that is you blank you want to buy, they have different patterns. At least that is the way for my 79
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
Old 11-04-2025, 10:56 AM   #3
Gotenntitans
Re: GM Key Blanks
Thank you. It does have a small “C” stamped on it. The door key has a “D” stamped on it.
Now I know.
GoTennTitans
1987 GMC Sierra
Old 11-04-2025, 11:51 AM   #4
ron350
ron350's Avatar
Re: GM Key Blanks
I used to be able to walk into a GM dealership and have them cut a new key cut with a key cutter. Factory keys are punched out using a key cutter instead of using a key grinder.
Don't know if GM dealerships still cut keys like they used to, A key cutter makes a much smoother cut so it does not wear out the lock tumblers like a ground key.
Stock 75 C10 step side.
350 2 BBL, 350 trans. 150K miles.
ron350 is online now   Reply With Quote
Old 11-04-2025, 01:34 PM   #5
bhc41051
bhc41051's Avatar
Re: GM Key Blanks
You could message member LockDoc I've bought blanks off him before.
https://www.67-72chevytrucks.com/vbo...d.php?t=707855
bhc41051 is offline   Reply With Quote
Old 11-04-2025, 01:43 PM   #6
Keith Seymore
Keith Seymore's Avatar
Re: GM Key Blanks
Silver is correct for '87.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 11-04-2025, 02:07 PM   #7
Getter-Done
Getter-Done's Avatar
Re: GM Key Blanks
Times 2
LockDoc is a Great person to do business with.
The early bird gets the worm,
85 Chevy K-20
Old 11-04-2025, 02:46 PM   #8
Gotenntitans
Re: GM Key Blanks
Thanks to all of you.
GoTennTitans
1987 GMC Sierra
