Old 08-05-2018, 09:35 PM   #1
ZEKE68
ZEKE68's Avatar
No adjusting slot on drum backing plate
My rear drum brake backing plates don't have a slot in them for adjusting the brakes. Is this the norm for our trucks? I have had other vehicles that I had to back off the brakes through the slot to get the drum off. Hate to have a drum stuck and have no slot.
1968 SWB Step Side, Big Block, 4L80E , Running!
ZEKE68 is offline   Reply With Quote
Old 08-05-2018, 09:48 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: No adjusting slot on drum backing plate
The knockout on these trucks is on the front of the drum (outside) instead of the rear backing plate. They are not punched very well and are a bear to knock out. It would be easier to take the drum off and drill them out....
LockDoc
Leon
Old 08-05-2018, 09:53 PM   #3
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
Yup.
~Steven
Simi Valley, CA
Old 08-05-2018, 09:55 PM   #4
ZEKE68
ZEKE68's Avatar
Will check that out, Thanks LockDoc
Old 08-05-2018, 10:08 PM   #5
ZEKE68
ZEKE68's Avatar
Just looked at the drums ( which I had off ), and there is not even a hint of a punch out. These are likely replacement drums. I was thinking of putting a hole in the backing plate that would fit one of those rubber plugs they sell.
Old 08-05-2018, 10:14 PM   #6
LockDoc
LockDoc's Avatar
I have never tried it but it should work. Let us know if you run into any problems with that.
LockDoc
Leon
Old 08-05-2018, 11:34 PM   #7
Stocker
20' Daredevil (Ret)
Stocker's Avatar
My K20 still has original drums, also with no hint of a knockout. Finally drilled holes in the backing plates and put in rubber plugs a number of years ago. Works great!
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 08-05-2018, 11:36 PM   #8
Steeveedee
Steeveedee's Avatar
Weird. I've punched literally hundreds of those knockouts out of drums and backing plates (trucks and cars). I guess the new stuff from Chinee isn't provided with that feature?
~Steven
Simi Valley, CA
Old 08-06-2018, 12:06 AM   #9
FL71C10
I just bought new drums for my 71 and they dont have knockouts. I'd be interested to see how you cut the holes in the backing plates. Drill holes on each side and then file out the middle?
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 08-06-2018, 12:48 AM   #10
toolboxchev
Its called "Value Added Processing" another words you guessed it they cheapened up the parts by removing a critical step in the casting.
Value added What?
toolboxchev is offline   Reply With Quote
Old 08-06-2018, 07:26 AM   #11
panhead59
Stocker says his original drums has no slots, so there's more to the story than cheap and/or replacement drums. So my first ? Would be to stocker- how do u confirm your drums are original ? Stamped part # maybe. Facts first
"You are not forgotten" USMC 75-79 (Aviation Ordnance Tech- F-4 Phantom)
1959 H-D Panhead. Owned since 1978. Currently with son in Lawton, OK.
1968 Chevy Custom SWB pick up. Fleetside. Lowered 4/6. Totally refurbished. 1966 Pontiac GTO. 4 speed. Saved original 389. Now has slightly built 455 engine. 355 rear gears. Very fun to drive !
panhead59 is offline   Reply With Quote
Old 08-06-2018, 08:49 AM   #12
ZEKE68
ZEKE68's Avatar
Think I would drill two or three holes, and then dremel them out.
Old 08-06-2018, 09:42 AM   #13
Stocker
20' Daredevil (Ret)
Stocker's Avatar
I have owned the truck since 1977 when it was 5 years old with about 50K miles. Pretty sure everything on the truck was factory original at that point, except the saddle tanks and rear bumper. If the drums had been changed before I got it, they would probably not be the same as whatever is available these days.
- Mike -
RIP El Jay
Old 08-06-2018, 12:59 PM   #14
littlehopper
I have a low mile 68 that has the knockouts outlined on drums. With under 40k , I am confident they are originals. Maybe later ones don’t have the markings for knockout.
littlehopper is offline   Reply With Quote
Old 08-06-2018, 04:11 PM   #15
57Suburb
57Suburb's Avatar
Don't blast me for mentioning this, but don't our trucks have a self-adjusting rear drum brake set-up. A few 10 mph reverse blasts, then lock up the brakes is supposed to adjust the rears drums. Might be why we see so many back plates with no holes?
1967 1500 GMC Stepside 6.0/6l90
1967 RS/SS Camaro 350/TKO600
57Suburb is offline   Reply With Quote
Old 08-06-2018, 04:40 PM   #16
FL71C10
The problem is when you want to take the drums off, it is nice to be able to back off a little bit on the adjuster to free up the drum.
Old 08-06-2018, 07:41 PM   #17
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Yes, especially if the drums have worn enough that there's a ridge catching the shoes and preventing drum removal.
Also, those adjusters operate in a nasty environment and may not work anymore. With luck, they can be cleaned & lubed and continue doing their job.
- Mike -
RIP El Jay
Old 08-07-2018, 08:04 AM   #18
68panelman
68panelman's Avatar
No blasting here, you are 100% correct.
68panelman is offline   Reply With Quote
Old 08-18-2018, 09:54 PM   #19
ZEKE68
ZEKE68's Avatar
Cut in brake adjusting slots in my rear drum backing plates to fit the rubber plugs I bought. This is so I can adjust the brakes initially, or back them off if I need to take the drum off, and it won't come off.
Old 08-18-2018, 10:14 PM   #20
Steeveedee
Steeveedee's Avatar
And you only have to do it once. It's worth all the sweat.
~Steven
Simi Valley, CA
Old 11-10-2025, 10:03 PM   #21
cshanek
cshanek's Avatar
I'm about 7 years late to the party but do you recall where you bought those rubber plugs Zeke68? Any reason not to just drill holes out of the drum?
cshanek is offline   Reply With Quote
Old 11-11-2025, 10:40 AM   #22
ZEKE68
ZEKE68's Avatar
I bought those plugs on Amazon ( Clipsandfasteners Inc 10 Brake Adjuster Rubber Dust Plugs ). I had to make an oblong hole for them.
Old 11-11-2025, 11:14 AM   #23
70STOVEBOLT
70STOVEBOLT's Avatar
You should not leave them open, as excess water could enter and make things nasty/rusty. NAPA offers the plugs in their brake shoe hold down kits, but I could not find them separately. Autozone sells the Dorman kit that has 4 plugs, see link below:
https://www.autozone.com/brakes-and-...2284644d3e6dfc
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 11-11-2025, 02:09 PM   #24
Rust_never_sleeps
Rust_never_sleeps's Avatar
Generic product at O'Reilly:
https://www.oreillyauto.com/detail/c...g/omx0/1676609
1970 C10 Custom longbed 350/350
“Carburetors are forgiving, timing is not” — Thunderhead289
Rust_never_sleeps is offline   Reply With Quote
Old 11-12-2025, 01:51 PM   #25
cshanek
cshanek's Avatar
Thanks all, I bought the kit Zeke68 mentioned, and will just drill a hole out of the backing plate.
