Old 11-12-2025, 08:23 PM   #1
Brettd85
Active Member
Sorry another fuel line question
I’m doing a frame off on a 72 blazer and purchased the lines from inline tube. Where does the 1/4” return connect? Is it to the larger 5/16” vent line?? There isn’t a return on the sending unit. I looked at the assembly manual but maybe the wrong year!? Thanks in advance!
Brettd85 is offline   Reply With Quote
Old 11-12-2025, 10:29 PM   #2
truckster
truckster's Avatar
Re: Sorry another fuel line question
There's not a return on the stock 72 Blazer. I connected mine to the vent line.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
1972 K/5 Blazer CST 4WD
1963 Corvair Monza Spyder Turbo convertible
1995 Camaro Z/28
truckster is offline   Reply With Quote
Old 11-13-2025, 10:26 AM   #3
hemi43
hemi43's Avatar
The fuel line kit might have included a return 1/4" line for those that install an aftermarket fuel injection system.
hemi43 is online now   Reply With Quote
Old 11-13-2025, 11:25 AM   #4
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: Sorry another fuel line question
1972 Series 10-30 350 with Turbo Hydramatic transmission called for AC brand fuel pump 40867, which had a 1/4" return nipple per the GM parts manual.
Old 11-13-2025, 01:23 PM   #5
DeadheadNM
Carpe manana
DeadheadNM's Avatar
This a photo from eBay and the seller may be mistaken. Another seller has the same p/n for a pump that lacks a return line. My 72's didn't have any fuel return line, just the vapor line iirc: https://67-72chevytrucks.com/vboard/...0&postcount=34
InLine Tube is famous for making mistakes
Old 11-13-2025, 02:43 PM   #6
1970cstblazer
Agree on ILT.
Here is the excerpt from the partsbook. Obviously, these have been wrong in the past and can't be considered gospel.
Old 11-13-2025, 07:54 PM   #7
Brettd85
Active Member
Hmm. Thanks for help so far. All the verbiage online says this 1/4” line replaces the factory one. So consensus is there shouldn’t be a return??
Where does the vent tube that goes forward connect to? I assume the charcoal canister but I can't find a hardline reproduced for that?
Old 11-13-2025, 09:13 PM   #8
hemi43
hemi43's Avatar
FWIW, that 1/4 "vent" return might be to prevent vapor lock. I know Mopars had these on their high performance engines, but they had it on the fuel filter.
This was used to send fuel vapor back to the tank in case the fuel boiled in the lines due to high temperatures. Maybe this was GM's fix.
My Blazer is a 1970 so I never encountered this.
https://www.moparts.ca/oer-1968-71-d...-426-440-mf282
Old 11-21-2025, 09:35 PM   #9
Brettd85
Active Member
I’m still having trouble getting confirmation on the 1/4” return and also if there is a hardline for the vent tube to run forward to a charcoal canister? Anyone?
Old 03-26-2026, 10:27 PM   #10
maldo
maldo's Avatar
I hope this help, I do not see a 1/4 return line in images.
maldo is offline   Reply With Quote
