Old 11-11-2025, 09:50 PM   #1
chris989
weatherstrip magic
Hello all,
Feels like all aftermarket weather stripping is either too big, too stiff or both
The other day i grabbed stripping from an 02 (CORRECTION 92-97) suburban and guess what?
It cost 5$ and fit great, trimmed a little and the door shuts with ease.
The aftermarket for my truck measures .850" diameter with a .115 wall
the OE 2002 measures ~.700 with a .085 wall.
I will test drive this week and unless it whistles or water comes in I will be grabbing some more next time I am at the pick a pull i will grab enough to replace the other.
Cheers,
Chris
chris989 is offline   Reply With Quote
Old 11-12-2025, 09:27 PM   #2
chris989
COrrection,
I was wrong about the year.
it was the 88-98 generation chevy.
I went back today and got all four doors for 11$.
Chris
Old 11-12-2025, 09:51 PM   #3
TKCR
TKCR's Avatar
Re: weatherstrip magic
That’s awesome!
Old 11-13-2025, 02:23 PM   #4
cwcarpenter98
cwcarpenter98's Avatar
How much did you have to trim off? Also, I’m assuming that the front doors from the OBS went to the front doors of your square?
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 350, Saginaw 4 speed
Old 11-13-2025, 03:55 PM   #5
chris989
I cut off 6 inches from the OBS driver door to fit the front driver door of the square body. I have not done the rears.
The truck i scavenged was in good shape. All the rubber was almost perfect.
All 4 doors for 11$.
Old 11-17-2025, 12:38 AM   #6
chris989
Update,
The rear doors of the 90s GMT400 burb are long enough for our rear doors.
all four door will fit with a little trimming. Not sure if buying new GMT400 trim would be fat and stiff. If someone purchases one day maybe they can chime in.
I got lucky finding all good rubber. many of the driver doors were toast.
Can't believe i have been dealing with the aftermarket garbage for so long and this took an hour to swap.
Cheers,
Chris
Old 11-17-2025, 08:42 PM   #7
straight6chevyguy
straight6chevyguy's Avatar
Thanks for the info! I will have to keep an eye out next time I'm at the pic n pull and try it for myself. My 78 needs door seals bad but wasn't sure I wanted to spend the money on new seals till after I repaint the truck in the near future.
1965 Chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601
1976 Chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037
1978 Chevy c20 350 4speed
1998 Chevy c1500 4.3L 5speed
1999 Chevy k1500 Suburban 5.7L auto 4x4
2002 Chevy s10 4.3L auto 4x4
1971 Mercury Monterey wagon 400 auto
Plus other misc. ... To many projects!
straight6chevyguy is offline   Reply With Quote
