Old 11-25-2025, 07:12 PM   #1
County
Verify axle code for me please?
I did a ton of searching, but axle codes are all over the place for truck/car, etc. Verify my findings?
truck 12 bolt. Passenger side tube reads THA W012 1 after hitting it with a wire wheel.
I THINK this is a 1971 12 bolt, 3.07 gears, non-posi. Is that correct?
Lower drivers rear on pumpkin rib has A 81.
Also has NF 3896838 (last digit may be 6?) raised on the carrier as well.
Thank you!
County is offline   Reply With Quote
Old 11-25-2025, 09:14 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Verify axle code for me please?
Thank you!
Yes, that would be correct. C10
Here are some codes I posted on here a few years ago.
https://67-72chevytrucks.com/vboard/...d.php?t=578793
Leon
Old 11-25-2025, 11:50 PM   #3
County
Thank you!
Old 11-28-2025, 04:32 PM   #4
LockDoc
LockDoc's Avatar
Thank you!
No problem....
Leon
